25-04-17, 08:48 AM | #1 |
Bleed nipples
Has anyone found somewhere selling Ti or stainless bleed nipples that fit the front caliper of a pointy?
I've bought a couple that all claim to fit and while the thread size and pitch is correct they're always too long. The picture shows my problem, shorter ones are what's fitted now and came with the calipers longer ones are what everywhere seems to claim are Suzuki m7 bleed nipples. Sent from my XT1580 using Tapatalk |
25-04-17, 10:14 AM | #2 |
Re: Bleed nipples
Will these do?
http://www.wemoto.com/bikes/suzuki/s...ainless_steel/ You can do a Wemoto by your model(I bookmark my bikes/models).Suggest you have a look around and buy a couple of things to use the postage cost. I've used Wemoto(World's End Motorcycles<grin>) for years.Great company/service. Tip:Even with Stainless I smear a little dielectric grease or ACF50 over them but not in the hole. As an FYI.Most Japanese Motorcycles use standard M10 1.00/1.25 pitch bleed nipples.Lengths can vary so you just have to get the right length ones if buying off say eBay. There are also,"Easy Bleed" nipples if you fancy, http://www.ebay.co.uk/itm/Goodridge-...-/301071168659
The Goodridge 'Speed Bleeder' is the perfect solution for eliminating the tedious, time consuming and repetitive job of bleeding brake systems, by simply replacing the existing bleed nipples. Their unique design incorporates a one way valve preventing air entering back into the system and eliminates the repetitive process of tightening and un-tightening...simply un-tighten the 'Speed Bleeder' 1/4 of a turn and pump the brake lever/pedal until the system is free of air and tighten!
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 25-04-17 at 11:52 AM. |
25-04-17, 10:17 AM | #3 |
John T
Re: Bleed nipples
I bought some years ago for my curvy. From a company called OEM but they seem to have gone now.
25-04-17, 11:22 AM | #4 |
Re: Bleed nipples
25-04-17, 11:37 AM | #5 |
John T
Re: Bleed nipples
I think mine were slightly longer but as long as there is enough thread to go into the calliper its fine. I seem to recall that the rear calliper on the curvey had a different thread pitch too.
25-04-17, 11:53 AM | #6 |
Re: Bleed nipples
Good point.I've slightly amended my post as some Japanese bike models use M10 1.25 pitch but you can't go far wrong with Wemoto and any doubts they are very helpful on the phone
25-04-17, 12:27 PM | #7 | |
Re: Bleed nipples
I've emailed a couple of places to see if they can get me some measurements so I can compare before ordering. Sent from my XT1580 using Tapatalk |
25-04-17, 12:47 PM | #8 |
Re: Bleed nipples
That sounds like the taper or size of the business end is wrong, they shouldn't leak just because they're longer than necessary.
25-04-17, 01:58 PM | #9 |
Re: Bleed nipples
That's what I thought and looking at my picture you may well be correct the original does look to have a fatter end
25-04-17, 02:02 PM | #10 |
Re: Bleed nipples
Have a look on Ebay for a company called Powerhouse. They specialise in calipers and refurbish them and do an exchange service. They also do all the parts and are quick to respond to messages. I have bought both S/S nipples and also a hanger (slide) pin from them for my SV650 SK3 rear brake (Nissin). Note that the nipple is slightly longer than the OEM part but the important part from the pointed end to the bleed hole is the same.
Correct bleed nipples for Pointy? | AkiraSV | SV Talk, Tuning & Tweaking | 9 | 12-10-13 04:50 PM |
bleed nipples | Nicky S | SV Talk, Tuning & Tweaking | 11 | 23-05-09 12:18 PM |
HEL Replacement Bleed Nipples don't fit SV | Ruffy | SV Talk, Tuning & Tweaking | 5 | 13-05-08 09:00 PM |
Bleed nipples | svrash | SV Talk, Tuning & Tweaking | 10 | 24-11-05 06:33 PM |
Damaged bleed nipples? | r1ck | SV Talk, Tuning & Tweaking | 12 | 11-03-05 10:01 PM |
