Old 25-04-17, 02:22 PM   #11
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Bleed nipples
The official part number is the same for my 1999 Curvy as the 2003 etc,
5912118410
You can check the correct year and model on here,
https://www.cmsnl.com/suzuki-sv650_model14123/
Old 25-04-17, 02:29 PM   #12
tom_e
Originally Posted by madcockney View Post
Have a look on Ebay for a company called Powerhouse. They specialise in calipers and refurbish them and do an exchange service. They also do all the parts and are quick to respond to messages. I have bought both S/S nipples and also a hanger (slide) pin from them for my SV650 SK3 rear brake (Nissin). Note that the nipple is slightly longer than the OEM part but the important part from the pointed end to the bleed hole is the same.
Perfect that's what I wanted someone that's used them successfully. It was actually powerhouse that I got my calipers from last year.
Sent from my XT1580 using Tapatalk
tom_e is offline   Reply With Quote
Old 25-04-17, 08:03 PM   #13
Blapper
Blapper's Avatar
Originally Posted by R1ffR4ff View Post
Will these do?
http://www.wemoto.com/bikes/suzuki/s...ainless_steel/
You can do a Wemoto by your model(I bookmark my bikes/models).Suggest you have a look around and buy a couple of things to use the postage cost.
I've used Wemoto(World's End Motorcycles<grin>) for years.Great company/service.
Tip:Even with Stainless I smear a little dielectric grease or ACF50 over them but not in the hole.
As an FYI.Most Japanese Motorcycles use standard M10 1.00/1.25 pitch bleed nipples.Lengths can vary so you just have to get the right length ones if buying off say eBay.
There are also,"Easy Bleed" nipples if you fancy,
http://www.ebay.co.uk/itm/Goodridge-...-/301071168659
  • Perfect Solution To A Tedious Job
  • Replaces Existing Bleed Nipples
  • Various Thread Sizes Available
  • One-Way Valve Stops Air Re-Entering System
  • Quick And Easy To Use
  • Fit And Forget
The Goodridge 'Speed Bleeder' is the perfect solution for eliminating the tedious, time consuming and repetitive job of bleeding brake systems, by simply replacing the existing bleed nipples.
Their unique design incorporates a one way valve preventing air entering back into the system and eliminates the repetitive process of tightening and un-tightening...simply un-tighten the 'Speed Bleeder' 1/4 of a turn and pump the brake lever/pedal until the system is free of air and tighten!
Marvelous R1ffR4ff! I'll have some of those for the next time. Wish I'd known about them before I bought the vacuum kit....
What thread is a curvy?
Old 25-04-17, 08:31 PM   #14
i use those nipples but i also use ptfe tape on the threads. no leakage.
did you clean the seat out before you put the new ones in?
Old 26-04-17, 07:20 AM   #15
R1ffR4ff
R1ffR4ff's Avatar
I'm almost certain they are M10 1.00 pitch but if you contact the seller(Demon Tweaks) with your details I'm sure they will respond.
The partsfiche doesn't give the dimensions.Once we know it can become common knowledge.
I've done a random check of different years and they all seem to have the same part number as previously posted so it looks like the front bleed nipples are constant across all models.
The rear ones are different.Even just counting the rings they are shorter and a different part number( 5912101A00 )
My old Honda CX500s are M10 1.25.
Old 26-04-17, 07:39 AM   #16
Blapper
Blapper's Avatar
Oh? I don't remember noticing a difference front/rear on my curvy.
Old 26-04-17, 07:42 AM   #17
R1ffR4ff
R1ffR4ff's Avatar
They have a different part number but sometimes even that is not a great guide(I prefer dimensions).If they are working,don't fix it
Only real way to check would be to put a rear and front side-by-side and use a micrometer but I can't be arsed to do that<grin>
Old 26-04-17, 07:51 AM   #18
Blapper
Blapper's Avatar
I'll do that before I buy the new ones, ta.
Old 26-04-17, 06:13 PM   #19
DomP
Try www.biggred.co.uk they specialise in all things brake calliper wise
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Correct bleed nipples for Pointy? AkiraSV SV Talk, Tuning & Tweaking 9 12-10-13 04:50 PM
bleed nipples Nicky S SV Talk, Tuning & Tweaking 11 23-05-09 12:18 PM
HEL Replacement Bleed Nipples don't fit SV Ruffy SV Talk, Tuning & Tweaking 5 13-05-08 09:00 PM
Bleed nipples svrash SV Talk, Tuning & Tweaking 10 24-11-05 06:33 PM
Damaged bleed nipples? r1ck SV Talk, Tuning & Tweaking 12 11-03-05 10:01 PM
