Wondering what everyone did today if you had the day off!
Spent half of it digging the cage out then the council came in with a digger! - got to meet some neighbours i didnt know, due to helping each other with the snow removal! To add, there really are some terrbile drivers out there. The first ones being those who even tried to go to work where i live & those who haven't a clue how to drive in the snow. They didnt know that revving the car in first gear would dig them in & rocking the car helps!
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
Stayed at home, removed the battery from the SV and worked on my college projects. I've given up on digging now as it seems as soon as I put the shovel down it bloomin snows again.
Does your dog/cat eat snow? | missyburd | Idle Banter | 25 | 12-01-10 01:43 PM |
Snow day... | Richie | Idle Banter | 85 | 09-01-10 11:16 PM |
got snow here | steveg | Idle Banter | 47 | 20-11-07 10:17 AM |
we got snow here | kwak zzr | Idle Banter | 26 | 20-03-07 02:52 PM |
Snow! | lukemillar | Idle Banter | 27 | 25-01-07 11:10 AM |
