09-06-06, 01:31 PM | #1 |
Suspension "Balance" question.
For the first time since getting the bike from new (August 05), I decided to increase the front preload by one notch after seeing my weight on the scales .
The front end seems to feel a bit better (more sure footed), but last night it felt almost as it the front wheel slipped a TINY bit in a couple of bends in great conditions. Should I adjust the rear preload too or should I wind the forks back a little? I'm assuming that only adjusting one has no real change to the geometry - right or wrong please? Cheers, Garry |
09-06-06, 02:02 PM | #2 |
It doesnt change the steering geometry at all. Thats done by steering height/distance. You're changing the spring load etc internally when changing preload, compression and dampening.
Front and back dont need to be adjusted in tandem. Far from it. Adjust one setting at a time, test, adjust again or move on if your happy. Unless you're a suspension expert thats the way to go. Thats my understanding. Feel free to tell me i'm wrong |
09-06-06, 02:45 PM | #3 |
If you improve one end and start taking advantage of it, it can make shortcomings at the other end more obvious... So it could just be that.
09-06-06, 05:47 PM | #4 | |
Garry |
09-06-06, 07:26 PM | #5 |
Changing the preload will change the steering geometry, a small amount of course, but it will do so, remember changing the preload doesn't make the suspension harder or softer, but it does change the point in the suspension travel you will be at under any given load.
09-06-06, 10:56 PM | #6 |
I agree
more preload on the front will raise the ride height a bit therefore changing the steering geometry by making the steering head angle less steep(at least that's my understanding) winding on some rear preload should balance it up not sure if the amount you changed the preload would make a noticeable difference to the steering though............... good luck Stev |
09-06-06, 11:43 PM | #7 |
Yep, while it'll change the geometry, we're talking about a sliding rear here, not a difference in turning characteristics... I've done big geometry changes, and you feel the difference, but not like this. I'd think you'd need a shock a yard long, or 6 inch forks, to unweight the rear to that extent.
Using "Pointy" Tensioners in a "Curvy"? | dtr125 | SV Talk, Tuning & Tweaking | 25 | 05-02-09 05:42 PM |
teh "what you doing this weekend thread"...sponsored by Chesley "Sully" Sullenberger the Third | keithd | Idle Banter | 30 | 18-01-09 11:47 AM |
Rideout "Sections" or "Groups" | independentphoto | Bikes - Talk & Issues | 19 | 04-09-07 01:08 PM |
A question for those with "stage 2" cams... | svrash | SV Talk, Tuning & Tweaking | 22 | 04-10-06 08:53 PM |
Front "Braker" or "Rear "Braker" &q | BURNER | Bikes - Talk & Issues | 9 | 27-02-05 01:04 AM |
