when i go backwards sitting on my bike and using my legs it seems alot harder than normal . like the brake is on a very little bit. any ideas ?????
Sounds like the brakes are binding a bit to me.
You could strip them, but after you get going and use them a bit they usually free up in my experience. |
is this when the bike is in gear with the clutch in? If not adjusted correctly it can apply a tiny amount of drive which is only noticeable when you try and move it
I find the same with my own at the mo, i tihnk it's the back brake however, as i only stripped the front calipers not so long ago.
Once you get going they free up. |
My brakes were terrible over winter, being sat out for 10 days in the salt when I went on holiday, I could barely push the bike. Two things you can do, clean all the calipers and pistons, or razz it around, thats what I did and it freed them up
I would try using your back brake a lot more then usual and see if that frees it up, else a clean up and maybe strip down would be a good idea.
Also check the wheel bearings, excessive tightness or free play in the wheel bearings, or excessive roughness in a wheel bearing whilst the wheel is rotating can indicate failure.
If you've been riding through winter, or regularly jet wash the bike then theres a chance they've rusted. Last edited by Xan173; 12-03-08 at 03:18 PM. |
#8 | |
Matt |
#9 |
Perhaps a bit of salt and winter muck. Try a good clean?
Thread Tools | |
Running in a new SV? | Baz | SV Talk, Tuning & Tweaking | 32 | 08-09-14 07:51 PM |
FI bike, starts ok, dad running and cut out when hot | the white rabbit | Bikes - Talk & Issues | 7 | 11-03-08 06:47 PM |
running in a new bike | steveg | SV Talk, Tuning & Tweaking | 14 | 02-02-06 12:14 PM |
Bike Running Bad. PLEASE HELP | Scoobs | SV Talk, Tuning & Tweaking | 7 | 02-03-05 03:06 PM |
bike running well again | Iansv | The Essex Lounge | 9 | 31-12-04 09:10 AM |
