25-04-20, 10:19 PM | #1 |
Junior Member
SV650 Build
Hi All,
Just joined the forum and I thought I would tell you about my SV, I bought it as a box of bits a couple of years ago and have finally got round to starting to put it back together. Got the swinging arm, wiring loom and engine in this week but held up for a couple of missing bits so hope to make more progress once bits start to arrive. It has obviously had a lot of money spent on it, all fasteners are titanium, forged wheels, M4 exhaust, SV1000 swing arm (I think), GSXR Forks (I think) fancy resets etc. and I am told it has a 700cc engine but took that with a pinch of salt, I shall get it dyno tested when rebuilt and that will give an insight into the engine. I will upload some pictures when I suss out how to do it. Cheers, Martin |
25-04-20, 10:30 PM | #2 |
Re: SV650 Build
It's possible, big bores do exist.. Should be fairly obvious on a dyno I would think
26-04-20, 06:02 AM | #3 |
John T
Re: SV650 Build
The big bore might be a James Holland adaption.
26-04-20, 12:34 PM | #4 |
Re: SV650 Build
I look forward to following your progress .... WITH PICTURES !!
Sent from my SM-G960F using Tapatalk |
26-04-20, 02:47 PM | #5 | |
Junior Member
Re: SV650 Build
I followed the instructions but every time it tells me it is an invalid format, the photos are 120kb jpegs I tried hosting on google, insert image, but when I preview the post it just shows the URL, no image |
26-04-20, 03:24 PM | #6 |
Re: SV650 Build
The forum image hosting has been broken for years unfortunately. I would suggest using imgur.com. I usually upload at 1280 x 1024. When you have then uploaded to imgur copy the 'BBCode' and paste on here
26-04-20, 04:01 PM | #7 |
Re: SV650 Build
postimg.cc is also really good, if that helps.
26-04-20, 04:54 PM | #8 |
Junior Member
Re: SV650 Build
Thank you Darren for help with photos, that is assuming this works!
Can anyone confirm the swing arm and front forks? Last edited by martinSV; 26-04-20 at 04:56 PM. |
26-04-20, 05:08 PM | #9 |
Re: SV650 Build
You could contact James at JHS racing and see if he has any recollection of working on it to get some clues about the engine cc.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
26-04-20, 05:10 PM | #10 |
Re: SV650 Build
That's definitely had engine work done
New season - New project SV650 build | Redmist | SV Talk, Tuning & Tweaking | 40 | 19-01-17 10:35 AM |
Sv650 minitwin/supertwin build | Rossco93 | SV Talk, Tuning & Tweaking | 6 | 06-02-16 06:54 PM |
Back at it, Turbo SV650 and build. | naturalextract | SV Talk, Tuning & Tweaking | 1 | 20-12-13 08:36 AM |
did Laverda build a better SV650 7 years ago? | SV650S_DUB | Bikes - Talk & Issues | 15 | 16-05-06 03:59 PM |
The SV650 Suzuki should build... | SV650Racer | SV Talk, Tuning & Tweaking | 22 | 19-12-05 02:25 PM |
