Old 08-07-05, 09:56 AM   #1
Ceri JC
Default Engine painting
I noticed the finish on my engine has started to flake in one place. It doesn't look too bad, but give the bike another winter's use and it could well look shabby. I've always fancied a black engine like in the curveys, so repainting the engine black could be an option. I'd only do the visible bits, paint it in situ, DIY job, etc. rather than drop it out of the frame and do the whole thing.
I know some people paint their exhausts (usually only the pipes, not the end can itself) in special heat resistant paint, to help fight corrosion but those usually look a bit matt and dirty. Can you get shinier gloss heat resistant paint and is it suitable for use on the engine casing (or does the engine exterior get much hotter than exhaust pipes?). Similarly, would such a paint also be useable on the front sprocket cover (plastic)?
Would this consitiute a 'custom paint job' that insurers would want to know about/take the mick with quotes for?
Old 08-07-05, 10:00 AM   #2
didge
You can get a glossy heat resistant paint my dads got some ill find out what its called for you
Old 08-07-05, 10:28 AM   #3
Iansv
Hammerite ??
Old 08-07-05, 10:31 AM   #4
didge
INSL-X Hi-Temp what the can sez
Old 08-07-05, 10:39 AM   #5
Ceri JC
Ta mate.
Ian: I didn't realise Hammerite was heat proof to high temperatures. Ah wonderful stuff, the WD40 of the paint world.
Old 08-07-05, 10:41 AM   #6
Iansv
I think it'd be ok, I bought some a while back but hadn't got round to doing it
Old 08-07-05, 10:44 AM   #7
didge
lol thought you would let him try 1st
Old 08-07-05, 10:46 AM   #8
Iansv
plan was to just do a small unnoticable area first to see what the result was....
Old 08-07-05, 10:48 AM   #9
didge
sounds like a plan
Old 08-07-05, 11:19 AM   #10
Ceri JC
Only other concern I can think of when painting over the existing paint, rather than stripping that first, then repainting, is would it increase engine temperature at all? Highly unlikely, but I was wondering if the heat resistant properties of it would make it an 'insulator'.
Painting a top box Mark_h SV Talk, Tuning & Tweaking 3 11-05-09 01:03 PM
Painting wilky007 Pennine Massive 3 20-03-09 10:41 PM
Painting engine ginger-(sv)ninja SV Talk, Tuning & Tweaking 5 10-09-07 09:29 PM
Painting K3 Engine cases Ratty SV Talk, Tuning & Tweaking 3 22-06-07 05:45 PM
Painting danf1234 SV Talk, Tuning & Tweaking 9 04-03-07 05:44 PM
