Old 14-10-07, 03:07 PM   #1
Flamin_Squirrel
Default Coolant - what to use
Bought some cheap coolant + distilled water from halfwits for a coolant change. Ok to use, or should I get something better quality?
Old 14-10-07, 03:36 PM   #2
Sideshow#36
Default Re: Coolant - what to use
Nah should do the trick. Distilled is always the way to go.
Old 14-10-07, 03:36 PM   #3
embee
embee's Avatar
Cheap coolant doesn't give much in the way of corrosion inhibitors and the life is limited. Some coolants can lead to premature water pump seal wear.
FWIW I use a "ready to use" coolant from a big car manufacturer, my choice is the Toyota Red, but others do good quality stuff too, particularly some of the long life Honda or VW/Audi stuff ("G12plus" IIRC).
There's nearly as much technology in coolant as there is in oil if you want to get nerdy about it. For the amount you use in a bike the extra cost is trivial.
There's nothing particularly special about bikes regarding coolant, the materials used are pretty much the same as you'll find in any modern engine/car.
Old 14-10-07, 04:13 PM   #4
Flamin_Squirrel
So do you think I should I chuck the stuff I just bought, or is it ok to use for a while?
Old 14-10-07, 08:14 PM   #5
embee
embee's Avatar
Likely to be OK, maybe just plan on another change in a year or 2 at the outside. Just make it 50/50 with the distilled/deionised water and worry about something else!
Old 14-10-07, 08:53 PM   #6
Sudoxe
I've got the halfwits stuff in my triple. But thats not saying much given my level of maintenance. But it seems to work.
Dan
Old 14-10-07, 08:58 PM   #7
I use the Halfords stuff too. Ask me in 5 years if it was a good idea.
Old 22-10-07, 03:16 PM   #8
hovis
is coolant the same as anti-freeze?
Old 22-10-07, 03:38 PM   #9
Smudge
thanks guys ive been searching for halfwitz all over the internet got some funny results though
coolant top up steveg SV Talk, Tuning & Tweaking 10 19-01-09 04:19 PM
Oil in coolant ?! fatneck Bikes - Talk & Issues 16 26-02-08 09:14 PM
Coolant help therealvw SV Talk, Tuning & Tweaking 3 07-08-07 08:02 PM
coolant leak SimJ SV Talk, Tuning & Tweaking 0 02-05-07 11:05 PM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
