Old 26-06-15, 08:21 PM   #11
PhilSV
PhilSV's Avatar
Default Re: Curvy Carb Question
Could it be the fuel pump?
PhilSV is offline   Reply With Quote
Old 26-06-15, 09:04 PM   #12
nutzboutbikes
sounds like carb setup to me, to rich on idle then with the cap removed its leaning off but this makes it to lean when getting on the throttle if that make sense!.
Old 26-06-15, 09:44 PM   #13
johnnyrod
johnnyrod's Avatar
Are you sure the chokes didn't interfere? The cables are pretty knackered, could be holding something open. Seems odd a second set of carbs do the same thing. I do wonder what difference having the TPS disconnected from the ignitor does, but this is a new problem. Hmmm..... Did you blow out all the jets in the carbs with WD40? So it also came out the back end (airbox end)? Have you checked the colour of the plug? And the other stuff? Need to tick off all the things before starting on something else - the rule of one - only change one thing at a time.
Old 27-06-15, 05:56 AM   #14
PhilSV
PhilSV's Avatar
Chokes tick
Jets all cleaned out tick
Connection check tick
Plug check today and thens it getting built back up ready for Snetterton
Old 27-06-15, 09:25 AM   #15
PhilSV
PhilSV's Avatar
ops:
So it ends, did the plug check and num nuts, thats me !, hadnt put the front spark plug in, well just
So there you have it apologies to all and many thanks to everyone whos chipped in with advice
Old 27-06-15, 10:42 AM   #16
nutzboutbikes
Good to hear you got to the bottom of it, is she running good now?.
Old 27-06-15, 11:24 AM   #17
PhilSV
PhilSV's Avatar
Yes very happy, ticks over at 800 a real treat and crisp through the rev range, it just needs a thrash ........
Old 27-06-15, 05:59 PM   #18
nutzboutbikes
Old 29-06-15, 07:54 AM   #19
ops:
Bwahaha, I've never done owt that daft, no not me.
Favourite also is knocking the front coil wires off when putting the tank back. "errr why have I got a 325cc single and no rev counter..."
Or another member on here reassembling starter system. "Oh noes YC... there's just a spinning noise, the starter clutch must have gone"... nope, you put the starter motor sleeve back 180 degrees out and it's spinning backwards!
Old 29-06-15, 10:07 AM   #20
jambo
jambo's Avatar
Yeah none of us has ever done anything that silly.
On an unrelated note an org member not a million miles from here was stripping a pair of forks a few weeks ago. The first one came apart nice and easy, the damper rod bolt on the 2nd one was a git. When it finally came out went straight into trying to knock the oil seal out. It really wasn't shifting, had a check after a while, the retaining clip is still there. Very stuck and subsequently bent at this point but definitely still there...
Jambo
Carb question sprocket SV Talk, Tuning & Tweaking 3 09-02-10 02:44 PM
Carb Question Sosha SV Talk, Tuning & Tweaking 7 22-06-09 04:18 PM
Carb Question - I am missing something fizzwheel SV Talk, Tuning & Tweaking 7 13-08-06 08:19 PM
carb question - Again 454697819 SV Talk, Tuning & Tweaking 3 14-12-04 02:11 AM
SV Carb Question Mike1234 SV Talk, Tuning & Tweaking 3 24-11-04 12:44 PM
