Old 15-07-19, 09:54 AM   #1
daktulos
daktulos's Avatar
Default Technology ...
I realise technology isn't everyone's thing, particularly when it comes to motorcycles, but I spotted this on the Suzuki SV650 page:
ADVANCED RIDER TECHNOLOGY
The SV650 is equipped with some of the most advanced rider technology available, including Low RPM Assist and Suzuki Easy Start System.
Does this really count as "some of the most advanced rider technology"?
daktulos is offline   Reply With Quote
Old 15-07-19, 10:24 AM   #2
Seeker
Seeker's Avatar
Default Re: Technology ...
I need the Suzuki Easy Start System because having to pull the clutch in that extra time to start the bike was wearing me out. I need to lie down just thinking about it.
(I'm not sure my Low RPM Assist is still working)
Most modern devices come with the V.H.A.S. (Verbose Hyperbolic Advertising Slogan)
Old 15-07-19, 10:46 AM   #3
SV650rules
The low RPM assist is so subtle it is easy to forget it is there, as for the one push easy start, what is that for, doesn't make the bike start any easier really, maybe saves a bit of battery ( and maybe the brushes in starter motor )..
2016 SV650 AL7
Old 15-07-19, 11:06 AM   #4
Othen
Excellent!
Sent from my iPad using Tapatalk
Old 15-07-19, 01:10 PM   #5
daktulos
daktulos's Avatar
I didn't know you didn't need to pull the clutch in! Awesome!
Old 15-07-19, 03:16 PM   #6
Scittyf
I'm sure you could wire it in a way you don't need to pull the clutch in.
Think I did that once when I had a remote start on a bike... Wasn't so great if you left it in gear though...
Scittyf is offline   Reply With Quote
Old 15-07-19, 05:34 PM   #7
Toooldtodie
Toooldtodie's Avatar
Got it on my GSX S1000. Just means you sit at the lights with the clutch near bite point with the engine revs at 2000 and the cooling fan cutting in... and it will still stall (tested) if you release the clutch anything other than REALLY slowly. Pointless, and it's listed as an advantage for large capacity V twins when it's an IL4. Gotta wonder.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 15-07-19, 05:53 PM   #8
Scittyf
I always thought that was a bit daft. I've generally only ever had carb bikes. If you wanted anti stall just increase the idle speed... same thing right
Old 15-07-19, 06:10 PM   #9
Toooldtodie
Or just rev the **** off it and dump the clutch!
Old 16-07-19, 05:33 AM   #10
Othen
I must have Suzuki Easy Start System on my K6 (I have soldered the two wires that normally go to the switch on the clutch lever to short them out permanently - I’ll decide when this thing starts, not the bike)...
Helmet technology Seeker Bikes - Talk & Issues 1 04-06-19 08:11 PM
Technology 1, hubby 0 Mrs DJ Fridge Idle Banter 0 11-01-14 10:34 PM
Technology timwilky Idle Banter 2 30-09-12 01:25 PM
Real Technology! punyXpress Idle Banter 1 30-01-10 06:20 PM
Scottish technology. quikstu Idle Banter 5 06-02-06 06:17 PM
