Old 30-09-14, 05:58 PM   #1
steady2wheels
Default Removing 'Kreem tank liner' from a petrol tank?
Hey guys, I have a little issue with my recently purchased curvy. The previous owner put 'kreem' tank liner in the fuel tank, this tank liner as many of you will know is no longer usuable with modern fuel as it blisters and peels and is hten carried into the carbs.
So my issue is getting the stuff out, I have heard from speaking to a few people that i shouls use either caustic soda or acetone, any suggestoins on which you think would be more effective or suitable would be appreciated.
Though that is not my main problem, the biggest bstacle i see is blocking up the holes from the fuel tap and the fuel cap, I thought about using a plumber's bung kit, but im guessing either of the chemicals would eat through the rubber and the corrisive chemicals would then ruin my lovely paint work.
So please any help or suggestions would be greatly appreciated, I might even buy you a beer
Old 30-09-14, 06:57 PM   #2
jambo
jambo's Avatar
Default Re: Removing 'Kreem tank liner' from a petrol tank?
Google "removing non-ethanol resistant tank sealant" and there are some sites that sell various chemicals for the task at hand.
To block the holes up on a tank I recently did, I took a short fat bolt, wrapped a load of gaffa tape around it and screwed it into the fuel sender hole, it was good enough for the time it needed to be sealed. For the hole which usually holds the fuelcock I used a thin strip of metal with 2 holes drilled in it for the bolts, and a little bit of rubber sheet to act as a gasket.
Jambo
Old 30-09-14, 07:37 PM   #3
squirrel_hunter
squirrel_hunter's Avatar
Kreem is compatible with the latest fuel additives. This is what I found when researching what to use to line the tank of the 2MA. So far, no problems. Though I understand some of the older stuff may not be. But so far I've only read anecdotal reports and no direct evidence.
The liner of my 2MA is holding up fine so far.
So why do you want to remove it, are you having issues with it?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 30-09-14, 09:45 PM   #4
steady2wheels
How did you block hte filler cap hole Jambo? Yes lots of trouble (by lots i mean tedious and continuous), the lining is reacting with the petrol, bubbling up and coming off and blocking the carbs, you can imagine my surpirse when i took the carbs apart and found lots of white gunk in them.
Old 01-10-14, 05:43 PM   #5
jambo
jambo's Avatar
My fix for the filler hole was to put a plastic food bag over the filler cap and then close it so the cap itself had a layer of plastic between it and the contents of the tank. Seemed to work fine for me
Jambo
Sent without a real keyboard
Removing Tank Pad? Aquila SV Talk, Tuning & Tweaking 3 28-03-10 11:24 PM
Removing the petrol tank yardar83 SV Talk, Tuning & Tweaking 7 12-05-09 10:39 PM
K1 Petrol Tank chasey Stuff Wanted 2 27-02-09 08:22 AM
Petrol Tank JamoSV650s Stuff Wanted 5 01-12-08 10:09 AM
Removing the petrol tank Suzuki sticker? PaulyMac SV Talk, Tuning & Tweaking 9 13-11-06 09:48 PM
