26-03-07, 08:57 PM | #1 |
Is it the rectifier?
Had a suspicion that the battery has had it as when I bought the bike as it had stood for a while over winter...or so I was told.
Charged the battery for 2 weeks, went for a 3 mile ride down the road....then had to be bump started by my mates. So I got a new battery and when I installed it I put the charger on it and it went straight into trickle charge mode. After riding all day yesterday and the bike starting much easier with the new battery in full force I thought it was fine, got home put the charger on and it went into charge mode not trickle, thought it was a bit odd as I had done 63 miles in all. So decided I best test the electrics tonight (put it off before). The voltage from the generator across the teminals was 92,17 & 17v and in the haynes it says a total of more than 70v so I'm guessing thats fine. The resistance also totalled up to over the 0.2 ohm it said was minimum. When putting the meter on the battery, lights on engine off = 13.9v and when holding revs at 5k like it says with lights on it dropped to 13.2v. Haynes said it should be between 13.5-15.5v iirc. So am I looking at a fooked rectifier? Cheers |
26-03-07, 09:11 PM | #2 |
Re: Is it the rectifier?
To be certain, are you saying that across one pair of alternator wires you've got 92V but across the other two pairs you have 17V from each? If so then the alternator, (or possibly the wiring thereof), is goosed. There should be a minimum of 70V from each phase not 70V total. Apologies if I misunderstand you, but we need to be sure of the results you have and from where they have been taken.
26-03-07, 09:27 PM | #3 | |
To clarify:
26-03-07, 09:33 PM | #4 |
correct, I'm pretty certain thats what we got and from reading the manual it said a total of 70v
did seem a little odd its not how you would normally balance 3 phase lol |
26-03-07, 10:14 PM | #5 |
I'm with Mr Squid. The 90,17,17 stood out straight away as being odd.
Suspect a faulty alternator giving an inadequate feed to the rectifier. Take measurements again as per Sid's post, then if you get the same results as we're thinking, change the alternator. Also, be ready for the possibility that the alternator fault has fubar'd the rectifier as well. Not nice news, but it can happen. |
26-03-07, 10:18 PM | #6 |
ok ill check it again tomorrow. cheers
26-03-07, 10:36 PM | #7 | ||
* There's no shortage of screwed SV reg/recs of course, but they seem to like doing that spontaneously, irrespective of alternator condition.
26-03-07, 10:47 PM | #8 |
See, I wasn't talking specifically about SV's. Just generally that alternator faults can cause rectifier issues
But yes, I see your point, a faulty alterntor doesn't always mean a faulty rectifier. Nice that the man is aware of the possibility though |
Thread Tools | |
I need a Rectifier / Regulator. | Marv | Stuff Wanted | 3 | 19-08-08 12:43 PM |
Its the rectifier i think | shortz | SV Talk, Tuning & Tweaking | 10 | 27-10-07 06:00 PM |
K2 regulator/rectifier, new in box | northwind | For Sale - SV's and SV related items | 0 | 22-02-07 09:14 PM |
Yet another rectifier thread... | instigator | SV Talk, Tuning & Tweaking | 15 | 25-01-07 10:50 PM |
rectifier | hovis | Stuff Wanted | 2 | 23-09-06 09:25 AM |
