15-04-10, 12:32 AM | #1 |
Gear 1 to 2
This is still not right, its beginning to **** me off now.
I sometimes (say once a ride) shifts into Neutral instead of 2, apart from looking like a complete prat, its very annoying lol, i have to shift harder han other gears to get to two. I still have the hard neutral when cold too. It never slips out of gear though so its probably not a bent selector? If it was clutch drag surely id have this issue through he rest of the gears?. So my attention is now shifted to the star shaped selector thing for the gear changing issue, with a bit of clutch drag making neutral hard and adding to my problems. Any thoughts? and no, the clutch is adjusted perfectly lol. Thanks Last edited by beabert; 15-04-10 at 12:33 AM. |
15-04-10, 01:16 AM | #2 |
Re: Gear 1 to 2
15-04-10, 01:30 AM | #3 |
Re: Gear 1 to 2
Yes indeedy
15-04-10, 02:23 AM | #4 |
Re: Gear 1 to 2
Is the shift lever in the best position for you?
15-04-10, 07:54 AM | #5 |
Re: Gear 1 to 2
I have exactly the same problem as you beabert, see here http://forums.sv650.org/showthread.php?t=148584 but to try and sort it im fitting a new cluch soon and will let you know if it makes a differance.
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
15-04-10, 08:46 AM | #6 |
Re: Gear 1 to 2
I had these exact problems, which were sorted by replacing the clutch plates. I expect this is what you will need to do...once done, you'll have your normal sweet suzuki gearbox back snick snick snick through the gears
15-04-10, 10:54 AM | #7 | ||
Re: Gear 1 to 2
Ill be waiting for your results geodude, cheers. |
15-04-10, 10:59 AM | #8 |
Re: Gear 1 to 2
I found my pointy used to do that... it wasn't due to age (barely over 1500miles on it) and I just remembered to give it an extra-firm shift from first to second, no problem!
15-04-10, 11:06 AM | #9 |
Re: Gear 1 to 2
I was thinking he clutch plates are so new they are all too close because of the grooves in my basket. I need to get hold of someone breaking a curvy engine with a known good unit.
25-04-10, 06:44 PM | #10 |
Re: Gear 1 to 2
Been out today after fitting new clutch and have no problems at all now (so far) everything seems smooth and happy. Gearchanges good and neutral a doddle and no creep. ok Beabert said i would let you know
Thread Tools | |
Gear Shift Rod bent - Gear Changing problem | Thaleshwar | SV Talk, Tuning & Tweaking | 13 | 05-06-10 06:28 PM |
Gear change problem-can't get past 2nd gear | muzikill | SV Talk, Tuning & Tweaking | 8 | 14-03-10 10:10 PM |
Gear change problem-can't get past 2nd gear | muzikill | SV Ecosse | 8 | 13-09-07 07:45 PM |
