Old 24-05-20, 05:51 PM   #1
Goldy69
Junior Member
Default Curvy starting problems
My bike was having an issue where it would crank but not turn over. Bought a new battery and it fixed this but the battery wouldn't charge so bought a new reg/rec and it still persisted. The battery voltage would decrease as you rev. Stator tests ok and reg/rec tests fine. Went for a ride yesterday and midway through the bikes clocks went weird and the bike died. Had someone jump start it and the bike would run but the dash was still being weird and sometimes the bike sounded like it was about to die. Rode home and the bike would not start again.
After charging battery again the bike now would idle but die as soon as you have any revs. However now the bike won't even start. Have checked spark and fuel. These are both fine.
I really have no idea what to check, it seems I fix something then another thing goes wrong lol
Goldy69 is offline   Reply With Quote
Old 25-05-20, 07:50 AM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Curvy starting problems
You need to do a systematic diagnostic exercise as per one of the guides on this site. It is pointless and expensive to just change bits without knowing what is wrong and a faulty charge system will destroy a battery quite quickly. You say you checked the stator and it was OK but did you check its output? That would be a good place to start if other checks show the battery is not charging.
Old 25-05-20, 08:59 AM   #3
Goldy69
Junior Member
Yes the stator was outputting approx 80v AC at 5k rpm. But the fact that the bike will no longer start at all baffles me.
Old 25-05-20, 09:08 AM   #4
R1ffR4ff
R1ffR4ff's Avatar
If you have a Workshop manual there's a troubleshooting section. It's quite often overlooked but can be a useful tool for diagnosing problems. As per other poster you need to go through a diagnostic regime.
If as you say it dies and you've checked the main things start on Electrical block connectors which can become corroded over time and cause no end of problems.
HTH
Old 25-05-20, 09:01 PM   #5
Goldy69
Junior Member
Default Re: Curvy charging problems
Thank you for your reply, here's an update.
Bike is now running i think the cutting out was due to a vacuum leak on the front carb as the rubber bung had a small crack on it.
The bike still has a charging issue though.
New battery, it sits at 12.2ish volts when idling, even less with the headlight on, decreases slightly when you rev.
Reg/rec outputting 14.8v on pos/neg, and the diodes tested correct. (This is also a new one)
Stator voltage at roughly 80v AC at 5k rpm. Has no continuity to ground. I did a resistance check and its getting 0.7/8 ohms on each pair of pins.
I went for a long ride, when i got back the battery was very low, in the 11V range. The bike still turned over but struggled.
Old 26-05-20, 09:10 AM   #6
R1ffR4ff
R1ffR4ff's Avatar
You say you have tested the R/R but have you done the full diagnostic as per the manual. If the Rectifier part(Diode tests) of the R/R is failing it will let AC current through which can damage the battery and would show as low voltage across the battery
Just in case,
https://cx500.000webhostapp.com/Mosf...sfetUniRR.html
Old 26-05-20, 04:11 PM   #7
embee
embee's Avatar
Originally Posted by Goldy69 View Post
.....New battery, it sits at 12.2ish volts when idling, even less with the headlight on, decreases slightly when you rev.
Reg/rec outputting 14.8v on pos/neg, …...
I'm confused by this. The voltage you measure at the output of the reg/rec should be near as makes no difference the same as at the battery (assuming they are actually connected together).
I'd be looking carefully at the continuity of the connection between the reg/rec out and the battery itself. Have you had a really good look at the main 30A fuse in the starter relay, and checked the wiring and connectors between the reg/rec and the battery, and of course the battery terminals and fasteners?
Old 26-05-20, 04:38 PM   #8
Goldy69
Junior Member
Yeah I did think it should be the same, it seems that the new reg/rec must be faulty as on the original at idle u was getting mid 13v and on the new one it was in the low 12s. I decided to wire the reg/rec straight to the battery as it was recommended in the forum's. Its now getting above 14v at idle but does still drop slightly with revs (however this might be normal?)
I will double check the wires from the reg but didn't see anything abnormal.
Old 26-05-20, 05:17 PM   #9
SV650rules
If you connected RR direct to battery and got higher voltage than you got before that confirms embee post that there is a high resistance joint between RR and battery when it is connected to normal wiring. As current flows from RR to battery some of the voltage will be dropped across the bad joint and never reach battery terminals...
2016 SV650 AL7
Old 26-05-20, 05:20 PM   #10
Goldy69
Junior Member
Yes I will investigate this. Do you think this could effect how the bike runs at all?
common starting problems curvy sv 2001? suzukijax SV Talk, Tuning & Tweaking 11 14-03-13 05:20 PM
Curvy starting and running problems. craig dow SV Talk, Tuning & Tweaking 6 27-08-12 09:28 PM
Curvy starting problems Ricerocket SV Talk, Tuning & Tweaking 10 12-03-10 06:48 PM
Curvy starting and Idling Problems gavinsky23 SV Talk, Tuning & Tweaking 13 12-10-08 08:55 PM
Curvy SV starting problems Bud SV Talk, Tuning & Tweaking 3 30-03-06 08:09 AM
