24-05-20, 05:50 AM | #1 |
Pointy clutch cover gasket - RTV for water pump?
Morning all. The stock gasket has pre-applied sealant around the water pump inlet and outlet. My replacement gasket is just flexoid (gasket card). Should I apply from RTV around the water pump passages before buttoning it back up?
24-05-20, 10:04 AM | #2 |
Re: Pointy clutch cover gasket - RTV for water pump?
I usually do but only a very thin smear if using non OEM gaskets. Blue Hylomar is good but can be a bit chewy to apply but most decent RTVs work well if correctly and sparingly applied and any excess wiped off where applicable.
Water Pump Cover Removal | Blapper | SV Talk, Tuning & Tweaking | 5 | 11-11-17 01:32 PM |
water pump cover for 02 curvy | tfboy | Stuff Wanted | 4 | 14-05-14 05:31 PM |
clutch cover and water pump change. | SV-Road-Warrior | SV Talk, Tuning & Tweaking | 5 | 10-03-14 10:49 AM |
Refinishing water pump cover? | alol | SV Talk, Tuning & Tweaking | 3 | 03-08-12 09:35 AM |
WTB 2005 SV650s clutch water pump cover | puffin04 | Stuff Wanted | 2 | 13-06-07 03:23 PM |
