Old 27-05-20, 06:07 PM   #1
Sean_Morgan
Default Delkevic
The Delkevic end can and high level link pipe were waiting for me when I got home.
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Old 27-05-20, 09:16 PM   #2
wsmc549
Default Re: Delkevic
Looks great
Sent from my SM-G973U using Tapatalk
wsmc549 is offline   Reply With Quote
Old 27-05-20, 10:38 PM   #3
zsv650s
Quite long for a hi level what is it 400.
zsv650s is offline   Reply With Quote
Old 28-05-20, 01:25 PM   #4
CheGuevara
That looks good. I've now had to contact them to see if they sell the link pipe on it's own.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 28-05-20, 04:11 PM   #5
Sean_Morgan
Its 350, I really didn't want to go much, if any, shorter. I'm not a fan of a stubby can
Old 29-05-20, 10:17 AM   #6
Dave20046
Dave20046's Avatar
Performance wise it's probably better.
Are you able to twist the link pipe one way or the other Sean (think it would be anticlockwise) so you can mount it at a sharper angle? It would follow the line of the back end a bit better then.
Old 29-05-20, 10:24 AM   #7
Sean_Morgan
I did have a play last night when I got home from work, I've got it sitting a little higher but am now limited by the indicator.
Old 29-05-20, 10:38 AM   #8
Dave20046
Dave20046's Avatar
Looks loads better that.
Time for some mini indicators
they're only about a tenner. Make sure you get bulb type, or if you want LED bear in mind you'll have to replace all four and add a relay unit.
Old 29-05-20, 08:34 PM   #9
Sean_Morgan
Already got the mini indicators, I'm just waiting for the infill panels for the fronts then they'll be on
Old 29-05-20, 08:50 PM   #10
Dave20046
Dave20046's Avatar
Proper job! That’ll look great
Delkevic exhausts pedro3178 SV Talk, Tuning & Tweaking 28 17-04-20 07:37 PM
Delkevic radiator Toooldtodie Ancillaries 1 23-10-15 05:38 PM
Delkevic end can Noddy For Sale - SV's and SV related items 9 08-09-14 10:07 PM
Delkevic? dannywride Bikes - Talk & Issues 4 17-08-14 10:44 AM
Which can Delkevic or MTC? sv650ollie SV Talk, Tuning & Tweaking 14 13-02-11 05:57 AM
