I am going to top up the coolant on my SV650S,and it says in the manual about using distilled water.Should i go and buy some,or will tap water be ok?
Judging by your location. Go out and buy some
Mix with antifreeze and top up
Not Grumpy, opinionated. Last edited by timwilky; 13-08-09 at 04:25 PM. |
use antifreeze; if pre-mixed, then just add, if concentrated, then follow the insructions on the bottle.
Antifreeze, aswell as not freezing until well below 0, will also have a higher boiling point and normal water ![]() ![]() |
Antifreeze is normally 50-50 with distilled water.
If you look at the premixed stuff most of it is that concentration. Halfords sell the pre-mix stuff |
coolant top up | steveg | SV Talk, Tuning & Tweaking | 10 | 19-01-09 04:19 PM |
Oil in coolant ?! | fatneck | Bikes - Talk & Issues | 16 | 26-02-08 09:14 PM |
Coolant - what to use | Flamin_Squirrel | Bikes - Talk & Issues | 8 | 22-10-07 03:38 PM |
Coolant help | therealvw | SV Talk, Tuning & Tweaking | 3 | 07-08-07 08:02 PM |
Sorry -coolant again | tomjones2 | SV Talk, Tuning & Tweaking | 6 | 17-06-06 09:47 AM |
