Old 09-05-11, 04:36 PM   #1
Cool I've joined the off the clock club
Well my speedo curvies speedo has decided to go wrong.
I've had the front tyre changed today and the ride home has come up with an interesting fault. Also tyre 1- fender extender 0
Had the lights on main beam and the speedo was averaging between 80 and bent on the stop pin. Pulled over and revved the motor and it was jumping of in own accord. Knocked the lights off or to the little running light and it was fine.
I know its a loose connection but really need to know where the connection is loose on the loom.
Thanks in advance
Andy
Old 10-05-11, 08:42 AM   #2
Geodude
Geodude's Avatar
Default Re: I've joined the off the clock club
If the front wheel has been off could it be the speedo sensor/rotor got damaged?
Old 10-05-11, 08:47 AM   #3
havent had a look yet, buts gt the hall marks of electrical.
If it is the sensor the fitters paying for it as the rotor was spotless and issue free in march
Old 10-05-11, 08:56 AM   #4
Geodude
Geodude's Avatar
I cant think of anything else, apart from hamfistedness maybe follow the wire up to the connector block and give it a check/clean.
Old 10-05-11, 09:38 AM   #5
Check the cable as it passes by the lockstops - seen the very same thing more than once.
It may not be there precisely that the cable is damaged - but that's the first place I'd look.
Old 10-05-11, 09:41 AM   #6
about to attack the bike with alen keys. Should know soon enough
Old 10-05-11, 03:08 PM   #7
looks like a dirty contact behind the headstock.
Good thing i've had the tank off as one of the clamps on the airbox rubbers was mainly oxidized metal. Explains the temprimental idle
Old 10-05-11, 03:49 PM   #8
Update again!
The gremlins there back!!
This time its any time the load/ resistance is increased on the electrics the speedo goes nuts.
Am I looking at a Reg/Rec or a short behind the dash
Old 10-05-11, 03:53 PM   #9
Geodude
Geodude's Avatar
Argh mate thought you had it sorted, where's yc when you need him. There should be an emergency yc button on the forum
Old 10-05-11, 03:57 PM   #10
Hahaha. Thats a case of beer and a bag of baccy
on the hunt for the number for the guy that does motorcycle electrics over the coast
Joined the triumph club steveg Bikes - Talk & Issues 27 05-11-10 02:02 PM
The first rule of cake club is, you do not talk about cake club... Paul the 6th Idle Banter 85 22-05-09 02:21 PM
Ive joined the IL4 Club... philbut Thames Valley 16 09-10-07 01:46 PM
Hello All , Joined the Suzuki club Watt_Bulb SV Talk, Tuning & Tweaking 13 24-02-07 12:15 AM
pointy clock cover(thingy on the back of the clock)!!!! ben650 Stuff Wanted 0 09-04-06 12:47 PM
