Old 14-07-05, 11:55 AM   #1
M65
Default Do I need to charge my battery?
Quicky. Ran out of petrol last night at midnight in the Lakes (long story). Anyway, while waiting for the cavalry to bring me some motion lotion, my battery went flat from waiting so long with my hazards on. Do I need to charge the battery again now? Bear in mind, I was on the motorway all the way home to Bolton (about 40 miles or so) doing a ton. Will this have fully charged battery back up or should Mr Optimate make an appearance?
Old 14-07-05, 11:58 AM   #2
Itching 2 go
get the charger out just to make sure
Old 14-07-05, 02:42 PM   #3
fizzwheel
fizzwheel's Avatar
I'd get Mr Optimate to do his stuff just to be on the safe side
Old 14-07-05, 04:03 PM   #4
M65
Will do. Cheers guys
Old 14-07-05, 06:01 PM   #5
Red ones
Red ones's Avatar
The speed you were travelling is pretty irrelevant. Once the engine is running above about 4500 rpm it will be charging as hard as it ever will (thanks to the regulator) so in fact you would be better off going a little slower and taking longer!
Old 14-07-05, 06:41 PM   #6
Biker Biggles
Biker Biggles's Avatar
If you want your battery to last it is a good idea to put it on the Optimate regularly(?weekly)to keep it in good condition.It doesnt overcharge the battery,just tops it up.
Old 15-07-05, 11:20 AM   #7
johnnyrod
johnnyrod's Avatar
If you use the bike regularly you don't need an optimate. If in doubt, charge the battery fully, lead acid batteries don't like being discharged.
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
How much would someone charge larigos SV Talk, Tuning & Tweaking 8 21-12-08 09:32 PM
battery wont hold charge taffo SV Talk, Tuning & Tweaking 14 29-12-07 08:04 PM
new battery - how to charge for first time ? Warren SV Talk, Tuning & Tweaking 18 03-12-07 09:43 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
