18-02-08, 10:15 PM | #1 |
HELP! - Bike Not Starting (Ticking Noise)
Hi guys and girls,
I've got a K4 SV650S and it not starting...just making a ticking noise and all the displays are flashing/flicking. It happend after I washed the bike, but it was only a light sponge down and a spot of lube on the chain...I can see how this could cause it! I'm new to all this...hence I'm asking the experts! Cheers in advance Ian |
18-02-08, 10:26 PM | #2 | |
Re: HELP! - Bike Not Starting (Ticking Noise)
-If the clocks come on, but it won't start - check the engine kill switch. -If it's not the kill switch - check the sidestand switch/clutch switch. Thought I'd put money it's number 1! Thanks Luke
#24 - Honda VFR400R NC30
18-02-08, 10:33 PM | #3 | |
Just been out to the garage to check both of them out, both seemed fine...then on my third attempt the battery died! If you have got any other ideas then let me know...looks like I need to buy a battery charger tomorrow! |
18-02-08, 10:40 PM | #4 | |
Anyway, as you say, go with the battery charger
18-02-08, 10:45 PM | #5 | |
I'll go with the battery charger (more money!) Cheers again! |
18-02-08, 10:59 PM | #6 |
19-02-08, 12:09 PM | #7 |
id say the battery is dead.. do you start it up alot without taking it out? i used to when i first got it.. because i hadnt passed my test and was showing my mates.. then i passed and the day i went to take it out... clicky clicky... GRRR
19-02-08, 12:16 PM | #8 |
Have you checked that the battery leads are clamped tight on the battery?
19-02-08, 12:32 PM | #9 |
Try jump starting it from a car with jumper leads ... the battery is under the riders seat, or just directly do it at the starter motor (the cable that goes to it is the +ve, earth out the -ve anywhere on the frame).
Remember, you are turning the motor here, so once started, remove cable! |
21-02-08, 12:33 AM | #10 | |
Top marks to Pete, the negative lead was loose on the battery and sparking when I tried to start it. The screw just drops in as if the battery connections are threadbare (seems odd as this is the first time I've touched the battery since owning the bike!) The bike is starting and running fine when the connection is taped down so I know this is the problem. So is it a case of a new battery as the theads seem shot, or are there tricks of the trade? Thanks again Ian |
What's that ticking noise? :/ | dyzio | Bikes - Talk & Issues | 3 | 30-12-08 03:03 PM |
Whats that ticking noise? | Stretch650 | SV Talk, Tuning & Tweaking | 43 | 21-10-08 08:20 AM |
Ticking Noise in engine | jamesnolan | Bikes - Talk & Issues | 24 | 12-12-07 12:03 AM |
ticking noise | dougieo | SV Talk, Tuning & Tweaking | 12 | 30-05-06 09:18 PM |
Ticking noise...... | Davies | Bikes - Talk & Issues | 20 | 07-03-06 10:25 PM |
