21-03-09, 07:44 AM | #1 |
Datatool system 3 PIN?
Ive been trying to programme the pin code as the instructions but it wont
accept any code, any ideas or do I need to disconnect for 6 hours after altering the pins? |
21-03-09, 08:05 AM | #2 |
Re: Datatool system 3 PIN?
1 - Disarm the alarm
2 - REMOVE THE IN LINE FUSE 3 - Ignition on 4 - Enter service mode 5 - Replace in line fuse 6 - Ignition off (Wait for confirmation beep) 7 - Press both button simutaneously (confirmation beeps) You now have 3 minutes to enter a new pin. For example if you want your pin to be 1234 1 - Set digit 1, ignition on, wait for for one beep, ignition off 2 - Ignition on press, wait for 2 beeps, ignition off 3 - Ignition on, wait for 3 beeps, ignition off 4 - Ignition on, wait for 4 beeps, ignition off You should now get a long tone, you now need to repeat the procedure to confirm the pin. If you are correct on your installation you'll hear 2 long tones, if you've failed you'll hear 3 short beeps. If you balls up at anytime, don't panic, disarm the alarm. If the ignition is left OFF for more than 3 minutes the alarm will go back to service mode. If the ignition is left ON for more than 10 seconds it will revert back to service mode. HTH EDIT: Just realised your's is a 3 pin so all the above might be complete bollox!! Last edited by cuffy; 21-03-09 at 08:41 AM. |
21-03-09, 11:58 AM | #3 | |
Nah, I think your right cuffy I read it as the alarm is a system 3, rarther than a 3 pin code
Blue naked K4 |
21-03-09, 08:22 PM | #4 |
Hi, it is a System 3 alarm and that’s virtually the way I have tried to program (twin button press near the start) I keep getting the 3 beep fail for some reason
22-03-09, 02:21 PM | #5 |
Just a thought... are you using 0 in your pin code, if so it wont except it and give you the short 3 beeps as incorrect
Blue naked K4 |
23-03-09, 02:49 PM | #6 |
No...just been on to Datatool any existing pin code needs to be erased first, they wont tell me the procedure and say its information only shared with dealers. He said the dealer will need access to the alarm itself which means pulling it to bits while Im there. Googlin hasnt brought it up, anyone any ideas?
23-03-09, 03:14 PM | #7 |
Contact the previous owner maybe ?
Blue naked K4 |
23-03-09, 03:32 PM | #8 | |
23-03-09, 04:46 PM | #9 |
Just been on to the first owner who also knows the second owner, hes going to call back
Im tempted to pull it off but it would be nice to use it if possible and it can be trusted..they are a rediculous price to buy.. |
23-03-09, 09:38 PM | #10 |
The Sick Man
as far as i know there is no 3 pin codes, its a 4 pin code for the S3
use the procedure in the datatool manual and its possable that the code has never been set so it will still be 0000
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Datatool System 4 Red | TSM | Bikes - Talk & Issues | 47 | 23-09-21 06:20 AM |
datatool system 3 | evertheoptimist | SV Talk, Tuning & Tweaking | 17 | 02-06-08 10:05 PM |
DataTool System 3 Problems | squirrel_hunter | SV Talk, Tuning & Tweaking | 9 | 25-04-08 08:39 PM |
Datatool system 3 | suzsv650 | Bikes - Talk & Issues | 1 | 04-07-07 01:26 PM |
Datatool System 3 | TSM | SV Talk, Tuning & Tweaking | 1 | 16-07-05 11:48 AM |
