Old 26-08-08, 07:34 AM   #1
Endellion
Default Help me lift my front wheel
Now I know this has probably been covered but I have looked and couldn't find an answer so...
I am after a new chain and sprockets soonish and want better acceleration. I am wondering what set or individual items I should buy, eg exact numbers of teeth for each sprocket. I have heard that 2 less teeth on the back is one way to go? Any help much appreciated. Do gold chains have any advantage over standard? Or do they just look good. I use the SV on the road only although next year I want to take it to the track.
Old 26-08-08, 10:02 AM   #2
punyXpress
punyXpress's Avatar
Default Re: Help me lift my front wheel
Fewer teeth on the back will raise the gearing & make wheelies less likely?
Old 26-08-08, 10:35 AM   #3
riktherider
if you want quicker acceleration, go one down on the front, or 3 up on the back. dont do both, its silly. tried it for a little while, but it just screamed without seeming to go that fast. think ive got the standard front with 3 larger on the back. lifts up pretty easy and doesnt effect top speed to much either.
Old 26-08-08, 10:39 AM   #4
olden mgroin
hey riktherider did you have to get a longer chain?
Old 26-08-08, 04:02 PM   #5
riktherider
not sure compared to the one i had on, might have had a link or two less. changed it all at the same time so couldnt tell you. normally when you buy a chain you have to take a couple out, cant remember how many i had to take out. might be enough movement in the rear wheel to accept it though.,
Old 26-08-08, 05:53 PM   #6
Dangerous Dave
The SV650 will wheelie with ease on stock gearing, altering the gearing only substitutes the skill required.
Old 26-08-08, 09:26 PM   #7
Endellion
Does anyone know what the best sprockets and chain for the job are?
Old 26-08-08, 10:29 PM   #8
jimmy-james
Tripple S chains and JT sprockets on mine nothing fancy but the gold chain looks sweet and does the job. If you are racing and want to save weight get an did X ring chain and Renthal sprockets but beware the light weight sprockets wear quicker.
Old 26-08-08, 10:43 PM   #9
Stu
Trinity
Stu's Avatar
Abba stand's probably easier than Block & tackle to suspend from the garage ceiling.
What?
Old 26-08-08, 10:46 PM   #10
SV-net
My road bike is a standard SV650 K3 with standard sprockets and chain and the front lifts ok with those on. In fact I find its quite light on the front as the 650 has a nice power delivery which can be used to its full potential with confidence. You need to learn this on standard gearing first because once its mastered then the fun can start, soon after this you will want to play with the gearing for more thrills.
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Abba front lift too short? lazymanc SV Talk, Tuning & Tweaking 8 23-09-08 03:18 PM
Bike Rear Wheel Lift Stoneyginger SV Talk, Tuning & Tweaking 11 15-04-08 02:07 PM
Need to lift the front of the bike off the ground lukemillar Bikes - Talk & Issues 13 11-04-08 07:15 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
