Old 02-02-06, 08:19 PM   #11
seedy100
When I came off the leaver sheared, and the rod bent.
New lever but straightened out the rod in a vice and I have had no problems at all.
In fact, I ended up with a K4 (I think) lever on a K3.
With the original lever I occasionaly knocked it down a gear by accident (OK I KNOW this shouldent happen); with the new lever which is straighter I no longer have the problem.
Old 05-06-10, 03:30 PM   #12
1952paul0
Default Re: Gear Shift Rod bent - Gear Changing problem
if the selector shaft is bent dont hammer it through the case. you will have to cut the bent bit off. forcing it through the case may well damage the case beyond use. ATB paul
Old 05-06-10, 04:39 PM   #13
husky03
husky03's Avatar
feck me if he's not got it fixed by now he'll need to give up paul (01-02-06, 04:01 PM )
husky03 is offline   Reply With Quote
Old 05-06-10, 06:28 PM   #14
beabert
lol
Help: 2nd to 1st gear changing problem AndyL SV Talk, Tuning & Tweaking 18 09-05-11 11:56 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
Gear Changing Problem ricky_t SV Talk, Tuning & Tweaking 6 08-08-07 04:41 PM
