Old 07-10-17, 12:18 PM   #1
DomP
Default Fork value
I'm getting tempted by a winter front end swap project, what might I expect to get for my ktech and emulatored 2010 forks in near perfect condition?
Whether I can afford to do the swap is a little dependant on what I can get back.
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 07-10-17, 01:03 PM   #2
Default Re: Fork value
TBH the only thing you are going to gain is better brakes (subjective as they can be too good) and comp/rebound adjustment but once they are set then thats it you should not be twiddling the clickers afterwords.
the above plus 'tart/bragging' factor.
its expensive when you add up all the things you need like mudguard, yokes, bolts, discs, wheel, axle, axle nut never mind depending on your weight you will need a spring upgrade and a service. the valving is harsh as stock as they are designed for the track. so in truth all you gain is better brakes which can actually be too good, pulling radial brakes in anger is a delicate job and requires a lot of 'feel' especially coupled with the engine braking of the SV. depending on how quick a rider you are you might be throwing good money away.
other factors are also an upgraded rear shock so unless you have already done that then dont do the front end swap and spend the money on the rear.
what you have in your forks is 90% performance of cartridge forks.
your bike though....
for the complete front end off yours your looking at around £250-300 if you can find someone wanting to buy it.
ooohhh and you will need to set up a speedo drive so extra cost there as well.
Old 07-10-17, 04:27 PM   #3
Stilo
Stilo's Avatar
http://www.ebay.co.uk/itm/Suzuki-Sv6...UAAOSwjRpZ0Jiu
Is this what you are looking for?
If you buy it I might be interested in your forks
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 07-10-17, 06:02 PM   #4
DomP
Yeah I've looked at that but hes uprated the springs for a 14st rider (I'm 10 to 10.5) and I'd rather but a complete end if I could.
Old 08-10-17, 08:54 AM   #5
Stilo
Stilo's Avatar
OK good luck with your search
Old 08-10-17, 09:01 AM   #6
DomP
Yeah I'm beginning to think 'what's wrong with the forks I have'
If everyone says I'm not gaining much by swapping why do so many people do the swap
Old 08-10-17, 11:39 AM   #7
PyroUK
PyroUK's Avatar
Because shiny
Also USD's, people love USD's!
Sent from my SM-G950F using Tapatalk
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 08-10-17, 11:40 AM   #8
tart factor plain and simple. the rwu 600 k1-3 forks are just as good but nobody uses them, that and better brakes. but what most people dont realise about the sv brakes is they need constant attention (once a year or two) to keep them in tip top condition and i'm not on about just cleaning them, they need a complete stripdown inc taking the pistons out and put back together with RRG.
Old 08-10-17, 11:47 AM   #9
DomP
Maybe I do 'need' usd's after all, to have a project as much as anything
Old 08-10-17, 12:25 PM   #10
at the end of the day its your bike
more things to be getting on with rather than a front end swap on the sv which should keep you amused for a good while.
if you do intend doing a swap then let the org help as there is more than what people think as to parts.
Replacing fork seals and fork set up? Ricky650 SV Talk, Tuning & Tweaking 11 26-03-12 02:20 PM
Fork oil air gap ccurts SV Talk, Tuning & Tweaking 7 20-01-08 11:23 PM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
Fork Oil to do with me! Daglad SV Talk, Tuning & Tweaking 4 22-11-05 06:08 PM
