16-05-21, 08:45 PM | #2291 | |
Re: What have you tinkered with today?
They said 'save it for the lawnmower ' ! |
16-05-21, 09:09 PM | #2292 |
I've used that stuff for years. Always started no problem after winter
16-05-21, 10:20 PM | #2293 |
VFR back together.. finally.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
17-05-21, 05:34 AM | #2294 |
17-05-21, 06:23 AM | #2295 |
Yes I have. It sounded very different to how I remember, which worried me, but then I might be over thinking it. It was in the garage too which amplifies the sounds. Possibly need to adjust the starter valves and idle now, but will test ride and see.
17-05-21, 09:18 AM | #2296 | |
https://sofemaonline.com/blog/entry/...aft-fuel-tanks
17-05-21, 10:21 AM | #2297 |
Phase separation is the main problem with ethanol in petrol in rarely used road vehicles.
https://petroclear.com/resources/don...e%20Figure%202).
2016 SV650AL7 2023 GSX-8S |
17-05-21, 11:05 AM | #2298 |
Keeping the tank full ( moisture comes from air above fuel ) can help, also adding a stabiliser earlier rather than later because once water has separated out it cannot be removed except by draining ( or maybe sucking fuel from bottom of fuel tank with a vacuum device like those dipstick hole oil change gizmos will get a lot of the water out ). https://www.amazon.co.uk/Sealey-TP69.../dp/B000WZF74M
I have the one linked to and have used it for a lot of things, including sucking out front fork oil without removing forks... https://www.goldeagle.com/tips-tools...es-against-it/
17-05-21, 06:43 PM | #2299 | |
Think I will contact Suzuki technical dept to see what they say. |
17-05-21, 07:23 PM | #2300 |
i would only imagine stabiliser is needed if you're not moving or running the machine for months, and its being left dormant.
