Old 12-05-19, 08:58 PM   #1
pharris79
Junior Member
Default F1 fault
Hi all, I have had my 2016 Sv650 just a few weeks, after washing it a few days back I noticed the engine management light on with a flashing F1 code.
The bike rides fine and I parked it up. Today I went out to see if it had ‘fixed’ itself and again I noticed not a lot wrong with the ride, however the display is not showing me ever being in 6th gear even though I am. Mechanically it’s fine! However is this issue known to anyone?
I’m totally sure it’s my stupid fault for washing it probably but I wasn’t to know...... appreciate any help here, I’m so sad.
pharris79 is offline   Reply With Quote
Old 12-05-19, 11:00 PM   #2
Talking Heads
Default Re: F1 fault
Did you use a pressure washer?
Talking Heads is offline   Reply With Quote
Old 12-05-19, 11:01 PM   #3
pharris79
Junior Member
Yes
Old 13-05-19, 01:39 AM   #4
Talking Heads
Chances are you've forced water in where it shouldn't be.
Old 13-05-19, 06:19 AM   #5
Othen
It has reported two different faults, so it sounds like water in the electrics. It might dry out (and the problem go away) - if you have somewhere dry but well ventilated to store the bike that might work, a hair dryer might work as well?
Sent from my iPad using Tapatalk
Old 13-05-19, 06:22 AM   #6
Seeker
Seeker's Avatar
There is an error code for gear sensor but you would need to put it in dealer mode to read it. I don't think that entering dealer mode has changed from earlier models:
https://tinyurl.com/y3vegm5e
(this explains more but is on a GSXR)
https://www.suzuki-forums.net/index....d-dealer-mode/
edit: The error code for the gear sensor is C31 "Gear position voltage is lower than specified value" (C00 = no error)
If it's a UK bike isn't it still just under Suzuki warranty, my 2016 came with a 3 year warranty although I don't know if that is transferable.
Old 13-05-19, 08:19 AM   #7
SV650rules
Pressure washers and vehicles are not made for each other. High pressure water can do a lot of damage to electrics and also force water past bearing seals, and even damage paint and underseal. I never use anything other than garden hose on cars, and bike never gets dirty enough to need a wash....
2016 SV650 AL7
Old 13-05-19, 08:20 AM   #8
pharris79
Junior Member
Yep figuring that now. Where are the electrics and connector for the gear shift indicators? Maybe I unplug and blow out, then leave in the sun? As said it’s fine mechanically so has to be this!
Lesson learned
Old 13-05-19, 09:27 AM   #9
Adam Ef
Adam Ef's Avatar
Check water hasn't got in under the seat and into the diagnostics connector (blanked off with rubber cap... the same that you use to get into "dealer mode").
I'd get it out to sit in the sun for a bit with as many panels, seat etc off and tank raised too if you can. Hope that any water that's got in may evapourate with the good weather we're having right now.
Past:
Old 13-05-19, 12:02 PM   #10
Seeker
Seeker's Avatar
The gear position sensor is situated under the front sprocket cover, it sits below sprocket. The connector sits under the tank near the left frame rail, looks like it has 3 pins and is roughly triangular in shape.
FI fault sv650s 04 Bikes - Talk & Issues 2 11-05-11 11:50 PM
c28 fault kcowgergmm SV Talk, Tuning & Tweaking 5 26-06-08 10:25 AM
one off FI fault DavieSV SV Talk, Tuning & Tweaking 24 21-02-08 11:08 PM
FI fault glang SV Talk, Tuning & Tweaking 0 19-12-07 04:49 PM
My fault? Carsick Bikes - Talk & Issues 15 14-12-04 02:30 PM
