Old 11-12-10, 03:14 PM   #1
L3nny
L3nny's Avatar
Default Car cooling system.
Please be gentle but I am a bit thick when it comes to mechanical things.
Driving my car today the other night and did about 10 miles, noticed the engine never got up to the normal running temperature. Sat at about a third of the way up the dial rather than bang in the middle as usual. It was -4 outside so didn't think too much of it.
Got in the car today and a big "Check Coolant" warning appeard on the display so I checked the coolant and the header tank was pretty much empty.
Now this is where I am confused, if there isn't enough coolant in the engine wouldn't it overheat rather than run cooler??
If it makes any difference the car is a VW Bora V5 petrol. Cheers.
2015 GS 1200 Adventure
Old 11-12-10, 03:18 PM   #2
punyXpress
punyXpress's Avatar
Default Re: Car cooling system.
Depends where the temperature sensor is
Now: Street Triple R
Old 11-12-10, 03:38 PM   #3
Dicky Ticker
Check coolant mixture is at the correct mix by topping up header tank to the proper level and running the engine before you check it after it has cooled.If during this operation the level has dropped again you have a water leak someplace so start by checking all the hose connections and condition of the hoses,then all externals such as thermostat housing and radiator looking for water traces or damp patches
The electric fan would kick in more if the coolant is low to keep the temperature down
Old 11-12-10, 04:08 PM   #4
Bluepete
Bluepete's Avatar
Thermostat?
IIRC, the thermostat stays closed until the engine is up to temp, then opens to allow flow from the radiator. If it fails, it could stay open and not allow the coolant to heat up.
Then again, I know nothing about cars...
Pete
Old 11-12-10, 04:20 PM   #5
Richie
fantabulas
Richie's Avatar
Originally Posted by Bluepete View Post
Thermostat?
IIRC, the thermostat stays closed until the engine is up to temp, then opens to allow flow from the radiator. If it fails, it Should stay open and not allow the coolant to heat up.
Pete
they are designed to fail in the open position to save your engine from over heating.
be thankful you haven't got and Audi A8 as the thermostat is buried deep within the engine and Labour charges are HUGE !
My Flickr photos
Old 11-12-10, 04:34 PM   #6
L3nny
L3nny's Avatar
Hmmmm, sounds like the same thing that happened to my Alfa.
I will take it to the garage and ask them to check it out. Cheers
Old 11-12-10, 04:39 PM   #7
Mr Speirs
Mr Speirs's Avatar
Does sound indicative of a stuck open thermostat.
And the lack of fluid might be the result of a small leak or an escape hole for steam...possibly the tank header cap has lost it's air seal.
Had to replace the thermosat on my Alfa when I got it too, easy job as long as it's accessible.
Old 11-12-10, 05:09 PM   #8
L3nny
L3nny's Avatar
I only work 1.5 miles from home and while I often walk, in this weather I have been taking the car. Do you think the fact I am using it for short journeys and not letting it warm up properly would cause problems?
Old 11-12-10, 05:34 PM   #9
keith_d
keith_d's Avatar
The oil and the exhaust system suffer from condensation and the battery doesn't get charged, but the coolant is usually fine with short runs.
Old 11-12-10, 07:50 PM   #10
punyXpress
punyXpress's Avatar
It'll never heat up in that distance IMHO
Minitwin Cooling system modification a.oneill45 Mini-Twins 6 12-11-10 09:03 PM
Filling cooling system - where and how? cringer SV Talk, Tuning & Tweaking 5 21-08-10 11:22 AM
How does the cooling system work? mattb200 SV Talk, Tuning & Tweaking 24 15-04-08 10:40 PM
sv650 and tl1000 cooling system riktherider SV Talk, Tuning & Tweaking 2 04-10-06 12:07 PM
Too much cooling help Bonart SV Talk, Tuning & Tweaking 7 29-12-05 09:15 PM
