Old 15-10-13, 12:28 PM   #1
pete m
Default ZX6R club re-joined
Can you believe my little devil is playing up - it almost had me off this morning, had it warmed up to 2 blobs, i hit the road, wind the throttle on and.......nada she died ....v worrying...
then going along the old kent road, it hit a pot hole , and died again....WTF ?
Help needed ...only thing to say is it sat un loved and unused all last week,. the headlight has only full beam, no dip...which bulb do i need ? could this be linked...?
An interesting case for Sherlock Mc Holmes of Crystal Palace by way of Hampstead....
Old 15-10-13, 01:14 PM   #2
atassiedevil
Default Re: ZX6R club re-joined
Sounds like a loose connection aggravated by hitting the pothole. The headlight will be a seperate issue, possibly switchgear or loose connection. Its an issue a few people have had.
Old 15-10-13, 04:06 PM   #3
jambo
jambo's Avatar
My memory's not awesome but I believe you had a ZX6R G model (98/99).
In which case the headlight's a single bulb for dip/main and an H4 is likely though I'd sugggest you check as I don't know that for certain. Start with the basics eh?
When you say died, I'm assuming total power loss, no instruments, no lights, no engine, nothing. and this has corrected itself? In which case a loose or bad connection is likely around something major along the lines for the main ignition switch or similar. Confirm the symptoms and I'll dig out a wiring diagram.
Jambo
Old 15-10-13, 04:07 PM   #4
pete m
Ta Taz ...are there any of the old guard left ?Crustaceans etc?
Old 15-10-13, 04:10 PM   #5
pete m
yes Jambo complete dead , threatens ...will check battery and report back --- ps bulb was either £5 or £10 from Halfords, i think its the 3 prong £$5 ...least i hope it is...
yes G1
Old 16-10-13, 10:50 AM   #6
pete m
Jambo - your help - as always - is much appreciated ....checked the battery connections and they seem fine so i agree with the loose connection theory ...but how to find it ...?
When you are bowling along and the thing just dies, its a nasty feeling...when you are pulling out from your driveway into the traffic, it dies instead of goes, that is distressing ....
Old 16-10-13, 05:37 PM   #7
TSM
The Sick Man
TSM's Avatar
Im sure ive got a sledge hammer, if not ive got a match.
Old 18-10-13, 11:36 AM   #8
jambo
jambo's Avatar
Breaking out the trusty Haynes manual.
Given *everything* dies and the main live & earth terminals are solid (you've checked both ends of these cables not just the battery end).
The main ignition live runs as a white line from the Starter relay, to the ignition switch, then as a brown wire from there back to the fuse block.
Check the connections are good at the starter relay, as well as any connector blocks along the way. Other wires would lead to failures of ignition, lights, or other systems but I don't think much outside of this loop would affect everything simultaneously as you describe. Note the wires, connectors and components on that route can all affect this, I would pay particular attention to the main starter relay and plug for the ignition switch into the loom.
Jambo
Old 18-10-13, 11:56 AM   #9
pete m
was that TSM offering to have a look ? Oh thanks you Ric ...
err - seems to be sucking air into the head so had a look - blimey oil all over rh side of engine ....now why would anyone talk about hammers and matches ?
Nice one Jambo, will try and follow the wiring as best as i can, have already done whats accessible, all seems well solid...
Old 18-10-13, 01:14 PM   #10
pete m
BTW - has Sid Squid lost interest ? thought he might have benefits of problem solving skills, or is he now an Eremite ?
Joined the club.... sv4me Photos 32 19-07-12 07:36 PM
I've joined the off the clock club andrewsmith SV Talk, Tuning & Tweaking 35 20-05-11 10:34 AM
Joined the triumph club steveg Bikes - Talk & Issues 27 05-11-10 02:02 PM
Ive joined the IL4 Club... philbut Thames Valley 16 09-10-07 01:46 PM
Hello All , Joined the Suzuki club Watt_Bulb SV Talk, Tuning & Tweaking 13 24-02-07 12:15 AM
