Old 26-03-20, 03:45 PM   #1
redtrummy
Default Front Fork seals
Help! 1999 sv naked Seals gone
I have removed the front forks but the bolt that goes into the fork directly above the axle just keeps turning. I have removed the spring rammed up a brush handle and with the wife holding the handle tried undoing it - still the same.
The only way I can think of progressing is to use a blowlamp on the old seal and melt it out. Has anyone any other suggestions? I am hampered by the lad being in lockdown and the wife not being very strong/use! (Sorry love).
I did try a search but could not see any relevant threads -If I missed one then I apologise
redtrummy is offline   Reply With Quote
Old 26-03-20, 03:58 PM   #2
redtrummy
Default Re: Front Fork seals
I have done it! I used a wood sash clamp and cut the brush handle down to size. It was because I looked for advice that the mind reset and I remembered the sash clamp not used for 20 yrs or so!
Old 27-03-20, 08:51 PM   #3
tojo82
I used an Allen end that fitted into my impact driver and shocked it out
tojo82 is offline   Reply With Quote
Old 29-03-20, 12:02 PM   #4
mrplasid
Junior Member
It is the worst part of the job. all i can add is keep trying. I think last time i used a couple of socket extension wrapped in tape and hammered onto the damper rod. alternatively, there is a tool for the job
https://www.ebay.co.uk/itm/JMP-Fork-...wAAOSwuARcRbr7
And buy or borrow an impact tool
mrplasid is offline   Reply With Quote
Front fork seals. Is this normal? tojo82 SV Talk, Tuning & Tweaking 4 02-10-15 07:38 AM
Replace dust seals when replacing fork seals? disco2 SV Talk, Tuning & Tweaking 3 22-05-13 03:03 PM
Poping front fork seals Dicky Ticker Bikes - Talk & Issues 5 12-06-08 04:02 PM
Indicator Problem & fitting front fork seals dannyboy81 SV Talk, Tuning & Tweaking 4 23-05-08 09:03 PM
Indicator Problem & fitting front fork seals dannyboy81 Bikes - Talk & Issues 0 19-05-08 08:44 PM
