Old 02-04-20, 04:52 PM   #1
egcSV650s
Default Chain Slider
Ive taken my swingarm off to check and grease the bearings and to give everything a good clean while ive got the time. Is this normal for the chain slider to be looking like this (apart from it being dirty) or should I get a new one especially as im changing the chain and sprockets aswell and going 1 tooth down on the front sprocket so the chain will be closer to the chain slider? Where is best to buy a new one from? Hope everyone is keeping safe and well.
egcSV650s is offline   Reply With Quote
Old 02-04-20, 05:27 PM   #2
mrplasid
Junior Member
Default Re: Chain Slider
I'm sure more Knowledgeable people will be around soon but i think it's a sacrificial part, so it depends how much meat is left on it. If it's about to wear through change it, if not clean and leave
mrplasid is offline   Reply With Quote
Old 02-04-20, 06:58 PM   #3
glang
Think that looks pretty normal but obviously if you run your chain slack it'll take more punishment. I think it's one of those that wears a lot initially and then settles down to a much slower wear rate....
Old 02-04-20, 10:29 PM   #4
egcSV650s
Thanks for your replies, ill give it a good clean and just make sure its not nearing to touching the swingarm but ill just make sure the chain stays tight
Old 04-04-20, 04:54 PM   #5
egcSV650s
just cleaned the chain slider up and noticed this at the bottom, im guessing its not meant to be like this
Old 04-04-20, 09:13 PM   #6
mrplasid
Junior Member
Yep, looks toast to me. They're not madly expensive though
Old 04-04-20, 09:58 PM   #7
egcSV650s
Wheres best to get them from
Old 04-04-20, 10:22 PM   #8
mrplasid
Junior Member
I got mine off ebay as new for £15
Old 04-04-20, 10:40 PM   #9
egcSV650s
Ive had a look on ebay and the only ones i can see is one for £52 new
Old 04-04-20, 11:04 PM   #10
mrplasid
Junior Member
https://www.ebay.co.uk/itm/174120844313
or
https://www.ebay.co.uk/itm/Suzuki-SV...4383.l4275.c10
chain plastic slider glang SV Talk, Tuning & Tweaking 4 22-10-18 01:59 PM
Velcro slider patches DryRob Bikes - Talk & Issues 0 24-03-15 01:50 PM
Caliper Slider Grease? Docara Bikes - Talk & Issues 7 22-03-14 08:11 PM
R&G slider - how much ? barwel1992 SV Talk, Tuning & Tweaking 13 25-11-10 03:25 PM
Frame Slider Bolts rick0361 SV Talk, Tuning & Tweaking 0 26-03-08 10:26 PM
