Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
25-04-19, 01:32 PM | #1921 |
Re: The All new Reeder Megathread
H'mm spark from the front plug is particularly weak, and disappeared after about 20 seconds when I ran the engine.
Drained the float bowls and checked the choke plungers too, but everything was fine. So do I replace the coil, as well as the plug cap. Cap didn't seem particularly secure in the HT lead, so may try trimming the HT lead back by about 10mm.
25-04-19, 01:46 PM | #1922 |
Have you cleaned out the plug 'well' and its drainage hole.
If ever you're really thirsty, that's where the water is, but it won't be nice to drink!
Was: K2 naked in rapid yellow - gone to a better? place Now: Street Triple R |
25-04-19, 03:25 PM | #1923 |
Its been in my garage for nearly 3 years, so its drier than the Gobi desert in the front spark plug tunnel
25-04-19, 04:10 PM | #1924 | |
should be 5000 ohms ( and as the man says anything north of 8000 ohms, bin it......). You can always take plug cap off the lead and try the spark from end of lead ( tape lead to side of head and let spark jump from centre of lead across insulation to outside where it lies against head ).
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 25-04-19 at 04:39 PM. |
25-04-19, 05:35 PM | #1925 |
Swapped the front & rear plug caps & coils, made no difference, still only firing on the rear pot.
Sprayed carb cleaner into the front carb, that also made no difference. The only thing I haven't changed is the front HT lead
09-05-19, 06:58 AM | #1926 |
Morning all.
Any luck with the bike so far Mav? |
09-05-19, 07:54 AM | #1927 |
Nope, fresh fuel, new HT lead and plug cap. Coils have been swapped round to eliminate a duff coil. Choke plungers are fine.
I'm stumped at the moment. Can't see any chaffing on the loom, but I haven't got round to undoing the tape yet So either electrical, blocked jet, or maybe carb diaphragm has perished and split?
09-05-19, 07:50 PM | #1928 |
Have you had another look at the spark on the front plug since swapping the coils to see if it is still poor?
09-05-19, 08:04 PM | #1929 |
Yep swapped them round too. It is firing, but opening the throttle it just doesn't pick up properly. Idle is rough and it's popping and banging on choke, and runs on the rear with the choke off, then it'll stall.
Front plug colour is normal and dry
09-05-19, 09:23 PM | #1930 |
Did you drain the tank before putting fresh fuel in?
RIP Andrew Reeder (Reeder) | alextg | East Anglian Revolution | 15 | 01-06-14 07:57 PM |
Sad News RIP Reeder | dizzyblonde | Idle Banter | 265 | 31-05-14 09:18 PM |
fao: Reeder... | speedplay | Idle Banter | 60 | 23-03-12 12:32 PM |
