Old 27-07-17, 02:13 PM   #1
Typhon219
Default curvy yoke conversion help
Hi all,
I'm in the middle of converting an 02 curvy s to take a handlebar. I've had to give it to my garage to get a couple of bolts loose and do a couple of other bits. They've just called to let me know that the top yoke I have from a naked curvy is a different size to the top yoke from my s and won't fit. I didn't spot any mention of this when I looked into how to do the conversion and thought it would be a straight swap, take off the top yoke from my s and drop on a top yoke from a naked. Does anyone know about this and if there is a way to get around the problem? Would it need the lower yoke from a naked to work?
Typhon219 is offline   Reply With Quote
Old 27-07-17, 02:29 PM   #2
Default Re: curvy yoke conversion help
the N and S lower yoke has a different part number for a reason (offset). most folk get the top N yoke to fit the S bottom by slightly forcing it on. no doubt someone will be along telling you different.
Old 27-07-17, 02:41 PM   #3
Typhon219
Thanks for the reply. Could forcing it cause any issues like the forks bending at the top? Would the bottom yoke and stem from a naked fit straight in and be a better solution? Sorry for all the questions, I just need to get the bike back together before monday
Old 27-07-17, 02:43 PM   #4
Typhon219
Hold up sorry, just re read yours and you said lower yoke, not top yoke.
Old 27-07-17, 02:45 PM   #5
21QUEST
21QUEST's Avatar
Bibio, on the Curvy, reason for the different part number is due to the N bottom yoke lock stopd being slightly different...it's slightly chamfered/step to reduce the turning circle on full lock.
My guess is, probably slightly bent forks or twisted bottom yoke.
Nemo me impune lacessit.
Old 27-07-17, 02:51 PM   #6
21QUEST
21QUEST's Avatar
What does 'different size's actually mean?
It should indeed be a straight swap.
Old 27-07-17, 02:51 PM   #7
i stand corrected
i would go with 21quest's reason then.
if your needing the bike for monday then stick the S yoke back on.
do you also have the longer clutch and throttle cables for the N conversion?
Old 27-07-17, 02:58 PM   #8
Typhon219
21 quest think they said the forks in the top yoke sat wider than in the bottom by 12mm. I'll have a better look when I go and collect it (wheeling it home)
Bibio yes I have a clutch and throttle cable from an n, as well as new braided brake lines from hel. Old brakes are off at the moment so if I can get the new bar on before putting the new lines on that would be better.
Old 27-07-17, 03:24 PM   #9
21QUEST
21QUEST's Avatar
Hello, provided it's 12mm difference on both sides(left and right forks), I'd say you do not have the right N top yoke.
Any chance of some pictures?
Old 27-07-17, 03:31 PM   #10
Typhon219
This
ABM top yoke conversion? Curvy. Aligowers SV Talk, Tuning & Tweaking 11 24-08-14 07:24 PM
Curvy stuff, yoke, clutch cable, spark plugs, handlebar conversion RenegadeMaster For Sale - SV's and SV related items 0 22-05-12 10:15 PM
faired curvy SV top yoke conversion guide? sicknote SV Talk, Tuning & Tweaking 4 05-03-12 09:29 PM
Tope Yoke Conversion? Hogzi SV Talk, Tuning & Tweaking 8 19-03-06 10:01 PM
Top yoke conversion Grinch SV Talk, Tuning & Tweaking 14 26-07-05 07:40 PM
