Old 03-02-11, 09:58 PM   #1
hardhat_harry
Default Curvy Cam swap
Finished mine today and started it up, sounded a little cam chainy for a couple of seconds then sounded great.
Took about 8 hours in all stripping and rebuilding the bike and all that plus I was being careful.
Oulton on Tuesday to try it out then dyno before the end of the month to see if there is any improvement on the last run with normal cams
Yay me!!!
Old 05-02-11, 10:54 AM   #2
NedSVS
Default Re: Curvy Cam swap
I did this mod a few years ago now and like it very much, especially for track day use. It didn't give me enough extra power to notice the difference by the seat of my pants dyno, but it does extend the useful rev range so you can hold a gear a little longer. At my first track day at Oulton, not long after doing the cam swap, I found it a lot easier to hit the rev limiter in the lower gears but I soon got used to it. Good luck with the weather on Tuesday - BBC 5 day forecast looks promising.
Old 05-02-11, 06:42 PM   #3
hardhat_harry
Finished everything I needed to do on the bike today, new chain, bodywork fitted.
One thing I have noticed when I hit the rev limiter I have fire coming out of the exhaust also it does the same thing when I shut the throttle then open it up quickly.
Anyone else seen this?
Looks cool btw I'll see it the track photo gets any pictures of the flames.
Old 05-02-11, 06:52 PM   #4
If you've got more fuel going in, because the valves are open for longer, then if it doesn't all get burnt in the combustion then its going to end up in the exhaust and ignite there?
Just my logical thinking, I could be wrong, I have been before
Old 05-02-11, 07:27 PM   #5
hardhat_harry
thats what I was hoping
Old 05-02-11, 09:52 PM   #6
NedSVS
Didn't happen when I did the cam swap but I noticed it on a dyno run I had before I got my Factory Pro stage 2 kit. I had lifted the Dynojet needles so much, to get good acceleration, that when you shut the throttle excess fuel was leaking past the needle/needle jet and burning off on the over run.
Old 05-02-11, 11:30 PM   #7
street racer
Due to the mixture being too rich and the excess is lighting at end, need re-adjusting
Old 05-02-11, 11:33 PM   #8
hardhat_harry
Its due at the dyno before the end of the month with its fast airfilter on for rejetting and testing.
Its at Oulton on Tues a trial run and Anglesea after the dyno run.
Old 07-02-11, 04:00 PM   #9
johnnyrod
johnnyrod's Avatar
I'm a fan of this mod too, I already had dyno set-up for filter/zorst. A dyno run after fitting the cams showed a/f fine all over (others have said the same too). You'll find a dollop of extra torque holding on the the red line, sot he power builds all the way up there instead of tailling off after 8k or so. Opens a few eyes on the track...
curvy- front end swap vzzzbuxt SV Talk, Tuning & Tweaking 14 06-05-11 04:46 PM
Frame swap - curvy to new Ady8 SV Talk, Tuning & Tweaking 3 11-07-10 08:46 PM
Curvy/Pointy wheel swap? curlylee Bikes - Talk & Issues 1 10-11-09 01:52 AM
TWF bearing for curvy f/e swap. chakraist SV Talk, Tuning & Tweaking 11 08-07-09 09:52 AM
Possible Blue curvy for swap c_noble For Sale - SV's and SV related items 2 19-08-07 09:44 PM
