05-01-12, 04:47 PM | #1 |
Curvy Cam Swap
I put the bike back together and rode it for the first time with the new cams (from a 2010 sv) today. I made this thread just to say, if you get the chance to do this mod to your curvy, DO IT!
My butt dyno registered more power across the rev range, and a huge surge in the powerband that definately wasn't there before. Also you can hold gears to the redline because the power doesn't drop off. All in all very happy, worth the effort, time and money spent. One note, 4 out of my 8 valve clearances were out of spec before the cam change, i dont know if that has an affect on performance, but all are in spec now. |
06-01-12, 09:31 AM | #2 |
Re: Curvy Cam Swap
It's ace isn't it? On the track you have a proper chance of beating up the 600/4 boys without resorting to Bloodrunner-style kicking them off or magnetic stick grenades on the tank.
06-01-12, 11:04 AM | #3 |
Re: Curvy Cam Swap
I can believe that. It feels like some one just poked my bike with a stick and woke it up!
06-01-12, 01:23 PM | #4 |
Re: Curvy Cam Swap
So jealous, are these things a bit rare (read pricey)?
06-01-12, 02:42 PM | #5 |
Re: Curvy Cam Swap
You have to keep an eye out for the K3 onwards intake camshafts, you wont find them easily. I bought an engine and will break it to make the money back.
If you're interested this is worth a read. If you can adjust your valve clearances you can do this. http://www.bayarearidersforum.com/fo...hreadid=154847 |
06-01-12, 03:03 PM | #6 |
Re: Curvy Cam Swap
How about the sound of the engine now? More agressive or throatier?
06-01-12, 03:09 PM | #7 |
Re: Curvy Cam Swap
Actually now you ask it seems much smoother. But that might be to do with having clearances in check.
06-01-12, 03:25 PM | #8 |
Re: Curvy Cam Swap
no real difference to be honest in sound etc. For me the cams brand new from Suzuki were about £140. I didn't need to adjust any clearances (before and after were the same) and a check on the dyno showed it didn't need any further work. It really is a good mod.
06-01-12, 03:28 PM | #9 |
Re: Curvy Cam Swap
My clearances were out before i changed the camshafts. In fact i think it was 5 clearances were out. All tight.
I suspect that was the bikes first valve check at 30K miles. |
06-01-12, 03:42 PM | #10 |
Re: Curvy Cam Swap
If you want more noise, get a different filter. The ignition advancer Woodruff key added a bit of crackle as well I think. The bext noise was a guy at Oulton Park coming over and saying, "Have you got a kit on that? (as in 700cc) I kept thinking 'I'll blow him away on the next straight' but I couldn't quite manage it."*
* This was in novices so willy-waving rights are fairly minmal! |
Pointy/Curvy CCT swap? | T0mmyGun92 | Bikes - Talk & Issues | 2 | 27-03-11 02:46 PM |
Curvy Cam swap | hardhat_harry | SV Talk, Tuning & Tweaking | 8 | 07-02-11 04:00 PM |
Frame swap - curvy to new | Ady8 | SV Talk, Tuning & Tweaking | 3 | 11-07-10 08:46 PM |
TWF bearing for curvy f/e swap. | chakraist | SV Talk, Tuning & Tweaking | 11 | 08-07-09 09:52 AM |
Possible Blue curvy for swap | c_noble | For Sale - SV's and SV related items | 2 | 19-08-07 09:44 PM |
