Old 03-07-18, 10:00 PM   #21
fchat63
Default Re: Oil leak with bike on Abba stand
So finally got to the point where I think I need a newclutch cover. Can’t stop the leak and tried everything I can think of.
Can one of you guys suggest the best place to get a clutchcover for a 1999 model? Reckon it’s going to be a non-original part or is itworth trying an original part from someone breaking a bike?
Is that the time?
fchat63 is offline   Reply With Quote
Old 03-07-18, 10:10 PM   #22
which part is leaking, the outer round cover or the main casing?
Old 03-07-18, 10:13 PM   #23
What Bibio said
If you need to replace it (it's got to be properly warped) new oem parts are available from fowlers
Sent from my PRA-LX1 using Tapatalk
Old 04-07-18, 05:22 AM   #24
andy650
If its the round centre leaking, it should be fixable?
I did mine by sanding flat on a sheet of MDF, and shortening the spacers, also by sanding. Didn't replace the oring.
Been leak free for a few years now.....
andy650 is offline   Reply With Quote
Old 04-07-18, 08:51 PM   #25
fchat63
It's the round cover that has the rubber o ring.
Maybe I'll give sanding it another go before I buy one.
What's the best way to check it for warping?
Is that the time?
Old 04-07-18, 09:03 PM   #26
place the cover on a flat surface and try to stick the thinnest feeler gauge you have at points round the cover. if the gap is more than 1mm then its fubar.
you can "lap" the cover by using a thick sheet of glass and grinding paste till the gap has gone. use a figure of 8 while grinding it and also rotate the cover every so often.
when installing the cover back on you must torque the bolts in a star configuration (opposing bolts) or you will warp the cover again.
all mating surfaces must be completely dry and clean without scores DO NOT USE A SCRAPER.
put all the bolts in
finger tight all bolts using star
half torque bots using star
final torque using star
if you still cant get it to seal then use a smear of JB Weld as a gasket sealer and let dry overnight.
Old 05-07-18, 07:18 PM   #27
andy650
I lapped mine with fine sandpaper, taped on MDF, far quicker than paste, and sealed properly afterwards with the old oring!
You must shorten the spacers though, otherwise they are too long and dont allow the cover to the nipped tight on the oring. I took about 1mm off them IIRC.
Old 05-07-18, 07:22 PM   #28
fchat63
Thanks Bibio,
I'll give that a go and post how I get on.
Is that the time?
Old 05-07-18, 09:22 PM   #29
good point andy made in shortening the spacers. though personally i dont like the taped down wet'n'dry, its not flat enough.
Old 07-07-18, 09:43 PM   #30
fchat63
So, do I push out the spacers and lap down the case then grind down the spacers so when they're back in they're level with the case. Then that should nip up the o ring when refitting?
Is that the time?
Storing a bike on an abba stand? AndyBrad Bikes - Talk & Issues 7 06-04-12 03:17 PM
Seat cowl and abba bike stand Fifteen15 Stuff Wanted 3 05-12-11 03:23 PM
Bike fallen off Abba Stand. lazymanc SV Talk, Tuning & Tweaking 54 03-05-09 12:26 PM
ABBA stand fitting on lowered bike? Bullwinkle SV Talk, Tuning & Tweaking 11 14-08-06 12:30 AM
Abba Bike Stand petevtwin650 Stuff Wanted 5 19-02-06 11:00 PM
