Old 30-03-06, 04:06 PM   #1
GSXR Carlos
Default Chain and Sprockets
Since we've been talking about chain and sprockets so much i was having a chat with a mate, he sggested going down a tooth on the front if i was going 2/3 up on the rear, any reason why i can't do this?
will i be ok with a 108 link chain instead of having to get a 110 for the bigger rear sprocket?
Old 30-03-06, 04:10 PM   #2
socommk23
no reason you cant do this!
will make the front v light on accelerating into the blue yonder! fun fun fun! lol
but would recomend larger chain! this will allow for any exess length you might need...if it too long just shorten it rather than buying one too short from the off! sorry i cant tell you the right length of chain for this.
trial and error! less of the error!
Old 30-03-06, 04:28 PM   #3
GSXR Carlos
how do you shorten a chain?
Old 30-03-06, 04:32 PM   #4
Stormspiel
Angle grinder
Take the "dome" of the last link you want removing and use a punch and hammer to nock it out. use a vice and some old rag to stop the chain twisting when you knock the pin out.
S'all i used to do with trials Renthal chains
Old 30-03-06, 04:33 PM   #5
socommk23
yup!
thats what i have done...nice and easy!
Old 30-03-06, 04:37 PM   #6
GSXR Carlos
oh if its that easy then
standard svs chain is 108 naked sv chain is 110, that's what i was refering to
if i was doing larger rear sprocket then i'd get the 110 chain, but if i'm going smaller front then i can stick with a 108 chain can't i???
i want me wheel to go skywards
Old 30-03-06, 04:43 PM   #7
jonboy
Default Re: Chain and Sprockets
No, it's just that the diameter of the sprocket will be smaller therefore making the links tighten more when they go around it and this will likely cause more wear leading to a slightly shorter chain and sprocket life, though probably not by that much if it's correctly lubed.
Yes, if you're making the front sprocket smaller why buy a longer chain?
By going down one at the front it's the approximate equivalent of going up three at the rear, so expect a big difference in acceleration off the line, and a very light front wheel .
Old 30-03-06, 04:47 PM   #8
socommk23
you are making the front smaller! but the back bigger! i think you would be safer getting the longer chain! cant be that much difference in price for piece of mind bout it fitting!
Old 30-03-06, 04:50 PM   #9
GSXR Carlos
no only the front smaller
Old 30-03-06, 04:59 PM   #10
jonboy
Therefore stick with a 108 chain IMO .
Chain And Sprockets squirrel_hunter SV Talk, Tuning & Tweaking 10 19-05-09 10:28 PM
Chain and sprockets pencil shavings SV Talk, Tuning & Tweaking 32 23-09-08 10:14 AM
New Chain and sprockets? gavinsky23 SV Talk, Tuning & Tweaking 14 05-03-08 12:13 PM
chain and sprockets adey Stuff Wanted 4 27-11-05 01:26 PM
Chain & Sprockets BaggaZee SV Talk, Tuning & Tweaking 23 12-01-05 07:07 PM
