Old 19-02-17, 08:58 AM   #11
Blapper
Blapper's Avatar
Default Re: Newbie from Cheshire question
Originally Posted by johna6968 View Post
Thanks for the replies.. Had a quick peep at the throttle body and throttle tube situation. Seems the throttle tube is hitting its housing stop before the throttle body is fully open. I can move the throttle bodies that bit further manually once the throttle tube hits full. There are no additional parts within the two halves of the throttle tube housing to restrict movement, just the step in the housing itself.
Sounds like the cables could be out of adjustment to me.
Old 19-02-17, 09:07 AM   #12
johna6968
Throttle cable free play is set about right, that did cross my mind tho. I would imagine with a bit of fettling of the throttle tube all should be well.. Cheers John
Old 20-02-17, 12:11 PM   #13
Corny Gizmo
Throttle restrictor is a T shaped piece of metal, it sits on the throttle body where the cable connects to the throttle body, it stops it rotating fully.
Old 20-02-17, 04:09 PM   #14
johna6968
Thanks for the info but no restrictors on my throttle bodies after checking. They open fully manually. Its the throttle tube that hits its housing first. Throttle cable free play is adjusted coerrectly too. The last bit of throttle body that isnt opening Im now putting down to an unmodified R6 throttle tube on my bike. I was taken back by not even having quarter of a turn for full throttle, seems thats roughly correct. With a bit of jiggery pokery should have it sorted.. John
Old 21-02-17, 04:53 PM   #15
Blapper
Blapper's Avatar
If your bike is a pointy, you do need to file back the stop using the original tube as a template. I've done this on sl0th's bike. If it is a curvy (like mine), it is a straight fit.
Old 22-02-17, 08:43 AM   #16
johna6968
Originally Posted by sl0th86 View Post
Yeah i recently put an R6 throttle tube on my K5 and you actually have to cut/file both sides so it opens and closes fully, not alot of people actually do that so im guessing it was just chucked on with no mods to the throttle
It does seem that way and did take a moment or two for the penny to drop on the throttle issue. Some fine tuning and Im sure all will be well Thankyou for all the replies and suggestions
Old 24-02-17, 12:16 PM   #17
jagryan85
Make sure you are ready for extra boomf in acceleration!!
Old 24-02-17, 12:47 PM   #18
johna6968
Im not sure I'd notice as its pretty much had most of its boomf from the day I bought it..
Old 24-02-17, 01:25 PM   #19
jagryan85
Even with a partly opening throttle?
Old 24-02-17, 01:26 PM   #20
Red ones
Red ones's Avatar
Just changing the grip isn't going to improve the acceleration. It will only reduce the amount you have to twist your wrist.
If you want to improve your acceleration you need to either change the engine or replace the gearing which then reduces the top speed.
Hello! Newbie from Cheshire speedyctr Idle Banter 5 28-10-11 08:30 AM
Newbie to all newbie’s and experienced riders / question. tonyk Bikes - Talk & Issues 17 03-06-08 08:12 PM
Another question from 'newbie' me.... 1world2wheels SV Talk, Tuning & Tweaking 3 11-06-06 10:30 AM
Question the newbie Law Idle Banter 19 13-04-06 11:13 AM
A newbie question. Jintel Idle Banter 5 03-03-06 09:29 AM
