02-08-11, 01:17 PM | #1 |
Suzuki bike of the month
02-08-11, 02:36 PM | #2 |
Re: Suzuki bike of the month
fank yooo big man
wife your not getting the morgage money this month |
03-08-11, 06:18 AM | #3 |
methinks a lot of those parts will fit the 650 650s ?
Im after a new left handle bar grip, end weight, and left foot peg so a few things in the bodywork list might be the same part no.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 03-08-11 at 06:27 AM. |
03-08-11, 06:41 AM | #4 |
If ever a bike needed a fender extender...
We are the Goon Squad and we're coming to town, BEEP BEEP! |
03-08-11, 08:20 AM | #5 |
03-08-11, 08:24 PM | #6 |
Maybe its worth keeping an eye on the suzuki bike of the month and post it in the main part of the forums. i just ordered the l/h bar grip rubber, same part for sv650 and busas. the parts dept said a few of the parts on the bike of the month list are the same for different models.
£11.50 before & £6.50 for b.o.t.m deal. The same grip goes for £15 on ebay atm. we may find a lot of the bodywork parts and some other parts are the same for some suzukis and save some dosh on oem. You could take advantage of this to build up some spare parts.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
04-08-11, 11:31 AM | #7 | |
Why not just give what's left of the Thou to me and I'll look after it for you . It'll look well in the garage next to mine which now has over 20K and 17 track days under it's belt. Ratty
"I can see Paradise by the SV's light" TCX Competizione S boots saved my foot . |
DRZ - Bike of the month | Owenski | For Sale - Other Bikes and General biking items | 3 | 13-05-11 11:18 AM |
Bike of the month offer | L3nny | SV Talk, Tuning & Tweaking | 6 | 07-01-11 02:40 AM |
Curvy is bike of the month on Suzuki website | Brettus | SV Talk, Tuning & Tweaking | 9 | 24-09-10 09:13 AM |
Suzuki Bike of the Month Curvy SV650 September only | andrewsmith | Bikes - Talk & Issues | 13 | 09-09-10 10:47 AM |
Bike of the Month | Dangerous Dave | Bikes - Talk & Issues | 20 | 20-12-08 04:53 PM |
