Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
19-02-21, 01:36 PM | #1 |
not heard of these before
2016 SV650AL7 2023 GSX-8S |
19-02-21, 03:08 PM | #2 |
Re: not heard of these before
i suppose if you have never seen them before they sound great and they are but are very expensive. one problem with them is is the copper wire is corroded or tarnished the solder ring wont take so gives you a false security. personally i use a proper solder joint and adhesive lined heat shrink.
19-02-21, 03:13 PM | #3 |
Similar to what is used on aircraft to bond the cable braid to the airframe.
Some of the low voltage signal cables use these on the internal braiding for the 0v line. That's going back to the 70's, the first Tornado cockpit I worked on as an apprentice electrician was full of them. We referred to them as solder sleeves, you had to insert a pig tail yourself. Sent from an S20 using Tapatalk with that kin cr4p blocked
Formerly known as Gajjii Previous Bikes: Red Sk1 Curvy, Red MT-07. Current Bike: Black MT-09. |
19-02-21, 08:58 PM | #4 |
You worked on Tornados? I used to love them when I was a kid. They used to fly over our house in pairs regularly.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
19-02-21, 09:37 PM | #5 |
Yeah, Avionics & flight systems mainly. Development fleet for most of my time at BAe. Basically getting poorly planes fit (enough) to fly.
Got to work on Harrier, Lighting, Buccaneer, Hawk (100/200), ADV, IDS, GR4, and an afternoon on a Spitfire before moving on to talk about work instead of doing any Sent from an S20 using Tapatalk with that kin cr4p blocked
Any one heard from … | andrewsmith | Idle Banter | 14 | 18-11-15 06:45 PM |
You've probably never heard of.. | Berlin | Idle Banter | 1 | 16-01-14 06:47 AM |
Have you ever heard of.... | 14990 | Idle Banter | 28 | 16-08-08 01:02 PM |
Ever heard of this? | SAMMY650 | SV Talk, Tuning & Tweaking | 6 | 26-02-08 07:07 PM |
Anyone heard from | Tara | Pennine Massive | 2 | 03-10-06 07:53 PM |
