26-12-05, 11:11 PM | #1 |
Starter motor servicing
Has any one attempted this job? Is it expensive for brushes/contacts? Is it worth it?
My reason for asking is that with winter starting and this motor doing over 65k, would servicing it make it more efficient at its job? |
27-12-05, 12:20 AM | #2 |
Not sure if they are interchangeable but I've got a starter motor from a K4 fuel injected bike for sale.
I would guess it would be easier/cheaper than servicing the old one. |
27-12-05, 09:51 AM | #3 |
If the motor is working then why are you worried, a general clean and a check of the brshes should suffice - IMHO you arre more likely to experience problems with the starter clutch than the motor.
27-12-05, 10:58 AM | #4 | |
The bits that would normally wear may not cost that much but I always like the 'easier' option so would always go for a good replacement myself. Infact almost most definitely better to get a replace as it would depend on what you find need replacing. Example Brush terminal set is about £20 Are you having problems with yours or just trying to be prepared due to milage etc. If that is the case then look for a good used one at a great price. Saying that I'm with John Burt . I would not even think about it if it's working great. No need to clean brushes etc. When it goes then I'll do something. Always good to have a few spares though Cheers |
27-12-05, 03:59 PM | #5 |
A block heater of some type would be more effective in helping winter starting, I keep my engine in good tune, it starts easily down to about zero (-15°C) once it gets below zero, I need to get my bike heated up with my salamander before I start it.
27-12-05, 05:32 PM | #6 |
RandyO you must have some decent gear to ride in -15c. I take the salamander you use to warm your bike up is not the lizard-type creature i'm thinking of.
27-12-05, 11:55 PM | #7 |
Go on then PM me prices for a starter motor and i'll consider the cheapest one
P.S. Don't forget to give me the approx mileage of the bike it came from |
28-12-05, 12:25 AM | #8 | |
Re: Starter motor servicing
28-12-05, 06:12 AM | #9 |
Yo Randy, what's up with our site? I've been trying all day. Jimmie. Like RandyO said, starter at that low miles? Should'nt need it. And what's so hard about servicing a starter? I mean come on. We're talkin basic's here. Brushes, commutator. ABC's. DUH !!!
Starter Motor | Grinch | Stuff Wanted | 0 | 02-04-08 10:24 PM |
Starter motor | lynw | Stuff Wanted | 1 | 22-02-07 01:41 PM |
Starter motor - curvey | svrash | Stuff Wanted | 0 | 14-06-06 02:37 PM |
Helen's starter motor | BillyC | SV Talk, Tuning & Tweaking | 38 | 01-09-05 08:07 PM |
starter motor and oil leak | gerbilion | SV Talk, Tuning & Tweaking | 3 | 01-06-05 06:17 PM |
