Old 27-08-08, 08:59 AM   #1
charlie13
Default curvy s headlight adjustment?
just wondering if anyone could tell me which way you twiddle the headlight adjuster screws to make the headlight beam go up and down. I need to set them a bit lower, but having had a 20 minute twiddle this morning I couldn't seem to make much difference to the alignment. I'm wondering if i've wound the adjusters out too much and they need to be re-attached.
I was expecting anti-clockwise on screws to lower the beam, clockwise to raise?
Old 27-08-08, 12:03 PM   #2
Dangerous Dave
Default Re: curvy s headlight adjustment?
Cockwise - Rasies the Beam
Anti-Clockwise - Lowers the Beam
Turning the adjusters to raise the height fully is actually doing up the thread so they will not be detached.
Old 27-08-08, 01:11 PM   #3
charlie13
Cheers for confirming that for me Dave, it sounds like by turning them anti-clockwise to lower the beam I could actually have undone the adjuster screws this morning, hence little or no visible effect on the beam while i was twiddling.
Old 27-08-08, 04:24 PM   #4
Dangerous Dave
Yeap, could have done but I am not 100% sure on how the adjusters are actually set up and whether they can be undone as such. See if you can have a good look at the adjuster, you'll need to remove the two side fairings though.
Old 27-08-08, 04:32 PM   #5
charlie13
i've just done exactly that, and the adjusters are an integral part of the headlight unit. the h/light unit itself is "rigidly" fixed on rubber mounts to the sub-frame. so i slackened off the subframe bolts, and it dropped down. guess the subframe must have got pushed up last time the bike was dropped and i never thought to check. just got to readjust the alignment on the lights now after all my tinkering. cheers
headlight adjustment on a K6 Pointy? Ollie_07 SV Talk, Tuning & Tweaking 8 28-03-12 05:16 PM
curvy headlight yorkie_chris Stuff Wanted 1 12-06-07 08:19 AM
Headlight adjustment Stu SV Talk, Tuning & Tweaking 8 02-10-06 01:24 PM
Naked Curvy with GSXR Suspension Adjustment Queries Ter SV Talk, Tuning & Tweaking 3 08-09-06 05:39 PM
Sv650S K5 headlight adjustment for the continent hutchy SV Talk, Tuning & Tweaking 4 11-04-06 01:44 PM
