21-09-20, 05:36 PM | #1 |
Tyre levers
New tyres arrived today. Looking to upgrade my (frustratingly) short tyre levers - any recommendations (or any to avoid)?
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
21-09-20, 05:58 PM | #2 |
Re: Tyre levers
I've used Motion Pro bead breaker levers for a while. Good quality. I don't actually use them to break the bead any more though as they take a long time to do it, working round a few times. I use an Abba bead breaker now instead. They're decent as levers though.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
21-09-20, 06:01 PM | #3 |
Re: Tyre levers
Tyre levers and alloy rims don't normally mix, don't you have a local place that fits tyres or are they too pricey...
Or as Adam says https://abbastands.co.uk/product-detail.asp?pid=12 Should pay for itself fairly quickly. How about balancing the wheels ?
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 21-09-20 at 06:05 PM. |
21-09-20, 07:19 PM | #4 |
Re: Tyre levers
Cheers both. I've got a bead breaker, a static balancer, rim protectors, and tyre levers - used to change plenty of tyres on supermoto wheels, so just looking to upgrade levers - mine are quite short and can make it a difficult task.
At the moment I'm looking at the JMP "pro" set - I saw the motion pro's but disregarded them as I didn't need the bead breaking feature, but I'll take another look.
21-09-20, 07:58 PM | #5 |
Re: Tyre levers
I use the rim protectors that came with the Motion Pro levers.
21-09-20, 08:52 PM | #6 |
Re: Tyre levers
I've got the clip on type, but if you cut out the sides out of plastic oil containers they work well, especially where space is tight.
21-09-20, 08:53 PM | #7 |
Junior Member
Re: Tyre levers
I use the Motion Pro levers but I have two sizes; two are about 11.5 inches long and one is only about 8.5 inches. They definitely benefit from being longer. If yours are the stubbier kind I can recommend the longer ones. They work great with rim protectors and a little soap.
Mine are the standard steel ones too, no bead breaker involved. I break the bead with a spare 2x4 and a car (use the tire as a fulcrum, push down on the 2x4... simple and has yet to fail on me) |
21-09-20, 10:27 PM | #8 |
Re: Tyre levers
Exactly . Is it worth the hassle trying to do it yourself for what it costs when the shop/dealer takes the wheels out , fits the tyres and balances the wheels ,refits the wheels and disposes of the old tyres ?!
22-09-20, 06:11 AM | #9 |
Re: Tyre levers
I use the tyre levers that came with my Abba kit, one long one short.
https://abbastands.co.uk/product-det...package&pid=38 They work well, now that my technique is getting better. More actual tyre removal, less swearing. I did my front tyre and bearing last night.
Currently driving a Corsa.... |
22-09-20, 06:54 AM | #10 | |
Re: Tyre levers
Yes. If you have more than one bike and one is a dirt bike with tubes that you swap between tyres on.
Set off tyre warmers will take upto a 190 rear tyre £80 | sv650k4 | For Sale - Other Bikes and General biking items | 8 | 01-10-13 11:07 AM |
Curvy Carbs, clutch levers and brake levers | 21QUEST | For Sale - SV's and SV related items | 2 | 03-03-10 11:04 AM |
Tyre levers | tigersaw | Idle Banter | 9 | 22-09-09 11:58 AM |
Road Tyre Pressures and tyre problems | G | Bikes - Talk & Issues | 14 | 05-06-08 03:29 PM |
Tyre levers - anyone here have? | Stu | Guildford Massive | 8 | 08-04-08 10:33 AM |
