29-06-14, 11:24 AM | #1 |
Curvy cuts out after 5/6000 rpm running.
As posted last month on curvy running poorly. My Bike is still sick. Problem is it starts ok, ticks over ok, then starts to run ok, I go through the gears then after about 10min I hit about 5k-6k revs it backfires violently and wants cuts off, I pull in the clutch and coast into the kerb. After a couple of mins it starts again for minute or two then just backfires and cuts out again.
I have to date Removed the tank and cleaned it out (some crap in it) but filter clean. removed all fuel lines and checked for restrictions (none). cleaned carbs ( some silt ). Fitted in line fuel filter, new spark plugs, air filter, and new suppressor caps for plugs. AND IT'S STILL THE SAME PROBLEM. can it be electrical????. Come on I bet someone can help. Thanks guys & girls. |
29-06-14, 11:58 AM | #2 |
Re: Test for all biking brains
Having a similar problem, check the floats and float needle are working properly, I think that my needle may not have been seated properly after I cleaned the carb causing excess fuel to enter the back cylinder.
I will know if I am right when I get it all back together! |
29-06-14, 12:06 PM | #3 |
i'll go with Haircut. sticky float valve.
Sv650 2003 running problem - cuts out. | Townfan10 | SV Talk, Tuning & Tweaking | 3 | 01-04-14 07:41 PM |
Engine cuts at high revs - Curvy. | Little blue | SV Talk, Tuning & Tweaking | 4 | 09-01-13 08:52 AM |
Curvy rear cylinder cuts out. | Draconis | SV Talk, Tuning & Tweaking | 17 | 02-08-12 10:42 AM |
Curvy won't idle reliably, cuts out. | phatwheels | SV Talk, Tuning & Tweaking | 19 | 29-05-12 08:43 PM |
I have rode 6000 miles and I will ride 6000 more.... | ooger | SV Talk, Tuning & Tweaking | 5 | 19-09-08 10:28 AM |
