Old 21-08-20, 09:00 PM   #1
DickP
Default Retrofit naked pegs onto 2000 SV650S curvy
Hi,
I am trying to make my 2000 SV650S more ergonomic for me and find the leg angle a bit too aggressive.
Would retrofitting the foot pegs from a naked reduce the angle of my knees but otherwise remain okay to ride, or would it throw out the riding position and cause a lot of back ache etc?
Thanks,
DickP is offline   Reply With Quote
Old 21-08-20, 11:04 PM   #2
GeorgeRYoung
Default Re: Retrofit naked pegs onto 2000 SV650S curvy
These
https://www.ebay.com/itm/REARSET-RIS...kAAOSwdGFYv1qs
can be used to raise or LOWER the pegs. I have long legs and this worked for me.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is offline   Reply With Quote
Old 22-08-20, 02:09 PM   #3
NedSVS
Thanks,
I've fitted naked foot pegs to my 2001 SV650S and fitted rearset riser plates upside down (I had to modify mine slightly to do this) to lower them about another 10mm. As they are moved back about 12-15mm as well as down and the standard gear change linkage rod for the S was still OK (if you fit naked pegs without the plates you will need the shorter gear change linkage rod from the naked model (part No. 25525-19F00). The naked pegs on their own weren't quite low enough for me. I no longer get cramp in my legs and have had no issues with ground clearance, even though my Avon Storm tyres are scrubbed to within mm's of the edge.
Old 25-08-20, 10:32 AM   #4
Hi,
Thanks,
If you can find some Buell footpegs, they are a straight swap for the Suzuki ones, drops the position by an inch or so
Or I have some of those riser plates which can be flipped to lower the footpegs, so long as you have a standard exhaust header pipe
Old 13-09-20, 06:21 PM   #5
DickP
Okay thanks for the help guys!
HID and projector retrofit - 2012 SV650S Participant SV Talk, Tuning & Tweaking 18 08-03-15 08:02 PM
SV Curvy Naked Parts Wanted - Clocks/Headlamp/LH levers & pegs etc. Ruffy Stuff Wanted 1 08-05-13 09:08 AM
FS 2000 (X) Naked Curvy Gordon B For Sale - SV's and SV related items 3 19-08-12 09:08 PM
For Sale - Curvy Naked 2000 BigFootIsBlurry For Sale - SV's and SV related items 14 03-08-09 05:27 PM
K4 swinging arm on 2000 SV Naked Curvy Sloth SV Talk, Tuning & Tweaking 3 29-11-05 02:21 AM
