Old 04-02-08, 02:51 PM   #1
Colby
Default Bolts on Reg/Rec stuck
Call me an idiot but is there a special screw driver needed to remove the reg/rec from a curvy?
On mine I have two big crosshead screw/bolt things but not like normal bolts/screws.
I tried a normal crosshead and a flat head screw driver and none of them fit well enough to undo the screw
Any ideas?
Old 04-02-08, 02:53 PM   #2
Keith1983
Default Re: Bolts on Reg/Rec stuck
I have no idea what it is you're trying to remove but it might be a torx screwdriver, they look a bit like a phillips head but with more slots.
Old 04-02-08, 02:55 PM   #3
Colby
Nope its not one of those. Its like a double flat head screw in an X shape.
Old 04-02-08, 02:57 PM   #4
hovis
i think mine was held on with 10mm sockethead bolts
Old 04-02-08, 02:58 PM   #5
Colby
yeah... i just looked at the parts fiche at Alpha sports and it looks completey different to what is holding the reg/rec on......
Bugger....looks like someone has bodged it....
Old 04-02-08, 03:13 PM   #6
hovis
sounds like they are phillips head screws?
Old 04-02-08, 03:22 PM   #7
Colby
They look like :
http://www.screwfix.co.uk/prods/1839...Bolt-M5-x-20mm
Old 04-02-08, 03:27 PM   #8
hovis
Originally Posted by Colby View Post
ohhhhhhhh
they are nasty little things, cos you cant get a screwdriver to fit properly.
a phillips is no good.......... you just need a big flat head screwdriver.
Old 04-02-08, 03:32 PM   #9
Colby
Ah... its not just me being a ham fisted nitwit then....
Old 04-02-08, 03:44 PM   #10
Alpinestarhero
Have you tried wacking the screwdriver with a hammer when its in the bolt? This might help to break it from the thread. Also, try soaking with e.g. wd40 overnight
Matt
Scamera van stuck deejay77 Photos 11 14-04-09 05:50 PM
stuck in gear thinman SV Talk, Tuning & Tweaking 4 25-03-08 02:03 PM
something stuck? Stingo Idle Banter 2 30-05-06 04:32 PM
Baffle Stuck Full Throttle SV Talk, Tuning & Tweaking 9 23-03-06 10:24 PM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
