Old 23-01-16, 04:57 PM   #1
Default Breaking curvy naked K1 - lots of trick bits
Engine - done a lot of miles, bit rattly but starts and runs fine and makes decent power. K1 version so no bother with oil starvation like earlier or throwing rods like later. Bought it at 18k and it's now on 100k. Oil changed every 3k, valve clearances every 12k usually.
£100
JHS stage 2 cams. Suit pointy or curvy, £150
M4 full race system to suit curvy. Would fit pointy but need mod to oil cooler £150
Penske 8987 triple clicker shock sprung for 12-13st rider. Fresh oil and service less than 1k ago though it's done over 40k in total it was like new inside... as you'd expect for a grands worth of shock. £300 sold
GSXR 600 SRAD/K1 hybrid front end. Right way up forks, 4 pot calipers, srad discs, K1 cartridges with very special midvalve-based compression damping. Braking response is awesome on them but they're slightly harsh on initial bump response, nothing you can't live with. £500 for the entire front end. Only issue is a dent on the front rim which motoliner could undent. £300
GSXR K1 clocks with connector and loom bits and speedo healer to make them work with the SV. £80. Also have small circuit to make rev counter work and parts to make a thing to make the fuel light work.
Ducati 999 caliper and fitting kit £80 or swingarm with good bearings including fitting kit and caliper and the lot inc braided hose £100
Stebel nautilus air horn, split compressor and horn connected with hose £20
GB moto rearsets bit rough some spares included £50
There's a load of other bits of random crap, the rest of the bike for one thing. Some rough as **** black plastics that have been down the road, repeatedly, a couple of fuel tanks, a set of (slightly rattly but fine to use) EBC prolite ductile iron SRAD discs. SRAD 750 yokes. Some ported SV heads. A wiseco 700cc kit. Some busa pistons. Lightened spragclutch/flywheel assembly. Total loss/lightened flywheel.
Old 23-01-16, 05:51 PM   #2
CB500Racer
CB500Racer's Avatar
Default Re: Breaking curvy naked K1 - lots of trick bits
How much for the ported heads, whats the condition of them are they curvy heads or injection.
Do you also have the setup info to go with the jhs cams too.
also what condition is the M4 system like, has it been down the road at all.
thanks
john
CB500Racer is offline   Reply With Quote
Old 23-01-16, 07:17 PM   #3
There's a small dent on the M4 link pipe, it would probably knock out.
The ported heads I'm not sure, they have just been matched to the manifold and 600 grit polished, slight smoothing on throat but very little, exhausts are matched and mirror polished. £150? They're clean spot on ready to fit. I was going to mill them down a few thou but thought you could get same effect by thinner gasket so didn't bother. (however my mate has first dibs on these just now).
Setup info for JHS cams... none needed, they have as-stock timing marks so easy to fit.
Old 23-01-16, 09:08 PM   #4
johnnyrod
johnnyrod's Avatar
Chris you had a rear hugger for a curvy, is that offer still there?
Old 24-01-16, 02:37 PM   #5
CB500Racer
CB500Racer's Avatar
Thanks for the info, if your mate doesn't want them give me a PM
John
Old 24-01-16, 03:13 PM   #6
Bunkle
Bunkle's Avatar
pm sent Chris.
Track - 2001 SV650, ZX10 shock, GSXR K6 Forks, wheel and radial callipers, full M4 race exhaust system.
Bimbling - VZ Marauder with a 600 Bandit lump
Bunkle is offline   Reply With Quote
Old 24-01-16, 04:32 PM   #7
yes if i can find it
Old 24-01-16, 07:15 PM   #8
N1xxl
Hi Chris you still got the M4? any chance of a couple of pics? 1 of link pipe damage 1 of can and 1 of full system fitted please whatsapp to:
07882157252 are you in Halifax?
Thanks
Neil
Old 24-01-16, 09:06 PM   #9
TOLAROS
TOLAROS's Avatar
Pics of the clocks?Do you have carbs?
For sale SV 2nd generation front fender, 20 euros
http://forums.sv650.org/showthread.php?t=128732
For sale one piece Richa racing suit
http://forums.sv650.org/showthread.p...39#post2470639
TOLAROS is offline   Reply With Quote
Old 25-01-16, 11:58 AM   #10
Yes have some carbs that are alright... been rejetted to suit bmc race rs filter (also for sale)
Lots of curvy fairing and bits Jammy For Sale - SV's and SV related items 0 10-06-13 11:51 AM
Lots of Curvy bits!! ibanezlynx For Sale - SV's and SV related items 32 06-10-11 12:19 PM
Need bits lots of bits sv650 2002 curvy K1 Nicky S Stuff Wanted 27 13-03-09 02:22 PM
Still lots of bits left 02 curvy mjf65 For Sale - SV's and SV related items 1 23-10-08 09:02 PM
Lots of Curvy Bits *****ALL MUST GO*******UPDATED 08/03/06 gc350 For Sale - SV's and SV related items 9 08-03-06 10:07 PM
