31-01-18, 07:27 AM | #11 |
Re: Linear or progressive front springs?
Just go with changing the oil and springs Geo, it'll tighten up the front end for the better.
Bibs suggestions are the gold standard upgrade, just go for the bronze upgrade.
31-01-18, 09:17 AM | #12 |
Mine looked terrible for years until one started leaking. Then I changed the seals. Then I crashed it.
Silver SV650SK3, Fuel exhaust |
31-01-18, 09:29 AM | #13 |
The stock springs are unbelievably rubbish. Linear is a better choice if you mainly ride solo, progressive can be useful if you ride a lot with a pillion. I would go for 15W oil. Changing the oil can be a pain, strictly you should take the fork legs out and tip them up, but there are threads on here about a sort of suction tube instead. Support the front end, take the fork cap off, remove the spacer etc., suck out fork oil. Replace oil and get the air gap right - about 105mm I think from memory, with no springs and the fork leg fully compressed (which is easier to do with the forks out, or at least take the front wheel out so you can push them up and down individually). Changing springs is simply a case of taking off the fork tops and pulling the springs out. If you don't already have the preload adjuster tops from later curvies them this is a good time to fit them.
08-02-18, 03:50 PM | #14 |
Sorry if this is a stupid question (which it probably is) but is there a top and bottom to a k tech spring? Point and laugh if it makes you feel better
Ps Thanks for all the pointers
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
08-02-18, 06:11 PM | #15 | |
the rate of the spring should be etched on one end, that end should go to the top for easy identification. if there is a tightening of one end of the spring (closer coils) then that end usually goes to the bottom. excuse the spelling i dont have a spell checker installed yet... lol |
08-02-18, 07:06 PM | #16 |
As usual Mr Bib's sir you have brought forth your mighty wisdom to save the feeble minded, I bow to you my liege lord
I owe you one of these but it will probably end up being one of these Seriously though, thanks all
20-03-18, 08:06 AM | #17 |
Is there anything I should use to clean out the old manky oil or just pump them and leave them upside down to drain out?
20-03-18, 08:33 AM | #18 |
Just turn them upside down and let them drain, give them a pump to help any out
20-03-18, 08:42 AM | #19 |
Why thank you kind Sir
.90 linear front fork springs? | tojo82 | Stuff Wanted | 0 | 14-09-15 09:31 AM |
Linear or progressive fork springs? | RedTop | Bikes - Talk & Issues | 13 | 13-09-13 01:44 PM |
Front progressive yacugar springs? Help plz | ice | SV Talk, Tuning & Tweaking | 3 | 03-05-11 07:37 AM |
Fork springs, linear or progressive? | TheStudent | SV Talk, Tuning & Tweaking | 40 | 07-05-08 03:27 PM |
Progressive or linear fork springs - the ultimate argument! | Jase22 | SV Talk, Tuning & Tweaking | 9 | 22-12-05 06:58 PM |
