Old 03-03-16, 03:55 PM   #701
admin
John T
admin's Avatar
Default Re: What have you tinkered with today?
Originally Posted by Swin View Post
With my wireless stat the most awkward bit was synching it to the receiver - supposedly it just needed the 2 battery trays to be pushed in one after the other, but I think it actually needed 5 goes and 20 profanities to allow it to connect
I bought mine secondhand to try as an experiment so the previous owner had done the syncing for me. The inside of the boiler has a rat's nest of wiring which was off-putting buy some research helped.
Old 03-03-16, 04:47 PM   #702
Swin
Swin's Avatar
if it's a battery powered stat make sure you google how it re-connects if the batteries need replacing - even with the documentation mine is a nuisance to do, nothing major just exasperating
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 03-03-16, 04:57 PM   #703
admin
John T
admin's Avatar
Cheers. Will do. I have the manual here to refer to also
Old 03-03-16, 05:59 PM   #704
Swin
Swin's Avatar
as long as you have the manual you're golden
Back on topic, I fiddled around with the exhaust on my wife's Yaris, it fell off
Old 03-03-16, 11:01 PM   #705
seanmhc
Got round to fitting lower fairings on my SV
Old 04-03-16, 05:48 AM   #706
mister c
mister c's Avatar
Won a cheap can off Ebay, so fitted it after work. Sounds very nice
Old 04-03-16, 07:26 AM   #707
NTECUK
NTECUK's Avatar
Mum's wireless stat was so unreliable I fitted a good old fashioned one.
Not a easy task to get a loom to it but it is done and saving money and emission s.
Old 04-03-16, 07:30 AM   #708
admin
John T
admin's Avatar
I'd normally go for the simplest solution but getting the wiring to our living room would be a pain. I've left the original in place so I can revert back if needed.
Old 04-03-16, 07:54 AM   #709
Swin
Swin's Avatar
Our stat was in an awkward spot which meant wireless was the best solution - it's been fine for 14 years now (apart from when the batteries get replaced, as mentioned before)
Car exhaust now replaced, not bad going as the garage reckoned the one that fell to bits was the original, 13 y/o one!
Old 04-03-16, 09:03 AM   #710
DomP
Any troubles lining yours up with the fixing holes? My right side was fine but just put r&g bungs on and it won't centre with the centre fixing hole.
DomP is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
