Old 19-03-18, 12:03 PM   #11
prisspringle
Default Re: fuel pump electic problems
Sorry for the thread revival but this is still an issue, only just getting time to sort it.
As it is I'm getting the right voltage to the fuel pump relay and out, including the soldered joint after the alarm. They only place I don't get 12v where it should be is the white fuel pump connection all I get is less than 0. 1v. From what I can see there's no more joints between so there must be a break in the wire or a bad connection at the plug?
Does that sound right?
Cheers again guys
Chris
prisspringle is offline   Reply With Quote
Problems with fuel pump priming, Pointy. Badeye SV Talk, Tuning & Tweaking 7 11-07-12 06:05 PM
Fuel Pump. K6 SV650 Noble Ox For Sale - SV's and SV related items 1 03-04-11 04:38 PM
k3 fuel pump assembly widget Stuff Wanted 0 13-05-10 12:23 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
