Old 10-12-14, 11:21 AM   #1
Default ADSL through powerline homeplug
Is it possible to take the Internet cable from an ADSL filter straight in to an Ethernet homeplug with some sort of plug adaptor? Then have the ADSL router on the other homeplug.
It is to avoid having two routers if possible
Old 10-12-14, 12:23 PM   #2
Amadeus
Default Re: ADSL through powerline homeplug
I don't think so, but I'm not sure why you'd need to. I have my modem going into my router, my router going into a switch, the switch going into home plug and then loads of devices plugged into other homeplug (via switch).
Old 10-12-14, 12:27 PM   #3
Same here
Old 10-12-14, 12:40 PM   #4
Spank86
It might.
It's not what it's designed for but if you were to get a cable that switches RJ14-RJ45 and another back the other way there's a possibility it would work.
I wouldn't hold your breath though, Ethernet allows packets of data to arrive at different times and be reassembled in the correct order, the ADSL signal has to arrive in synch with the far end so it would likely cause problems, Amadeus' solution is a far better one (although the way he's phrased it sounds overly complicated).
If you have power by your phone line simply take an ethernet cable out of the modem and into the homeplug then another one out of the far end and into a switch/hub/router (whatever you want to call it) and then off to your devices.
Routers take very little power to run (the BT hub about £11-15 a year) and are designed to work in this way.
Old 10-12-14, 01:01 PM   #5
Fair enough. It's because the main phone line is in my bedroom and I'd rather not have a router ticking and flashing if I can help it.
Old 10-12-14, 01:04 PM   #6
PyroUK
PyroUK's Avatar
Cover the lights with a bit of paper?
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 10-12-14, 01:15 PM   #7
atassiedevil
Although it's not recommended, you can run the router off another phone socket, rather than the main one
you'll see perhaps a little loss of speed, but nothing huge.
Old 10-12-14, 01:16 PM   #8
Skip
Skip's Avatar
Use a long ADSL lead and run it into another room?
http://www.ebay.co.uk/itm/like/25119...f14=108&ff19=0
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 10-12-14, 02:02 PM   #9
Dipper
Dipper's Avatar
Do you have other phone sockets in the house? If so it could be possible to make one of those the main socket if you've basic wiring skills and your cabling has 3 twisted pairs (6 cores).
Dipper is offline   Reply With Quote
Old 10-12-14, 02:10 PM   #10
Only one phone socket unfortunately and laminate flooring so don't want to be tripping on cables.
ADSL Filters DarrenSV650S Idle Banter 21 16-01-12 04:21 PM
Router / ISP / ADSL Advice fizzwheel Idle Banter 54 07-11-08 02:08 PM
Computer question; ADSL microfilters? Kilted Ginger Idle Banter 6 21-06-06 04:25 PM
Good range Router/Adsl modem/Wireless Access point? thor Idle Banter 16 08-02-06 04:16 PM
